service history from vin#?
doubletapdrew
What about this vehicle? 1GNFK130X7J186423
Vehicle Information
VIN: 1GNFK130X7J186423 Model: CK10706-2007 TAHOE 4WD LT
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Service Update Bulletins N070007 07007 SERVICE UPDATE - REMOTE KEYLESS INOP/BATT LOW-GMT900 ONLY-*EXP W/BASE WARR* 02/06/2007 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: RQDTK0HR XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Limited Warranty 04/03/2007 243 MI 04/03/2010 50,243 MI
Corrosion Limited Warranty 04/03/2007 243 MI 04/03/2013 100,243 MI
Emission Select Component Ltd Wty 04/03/2007 243 MI 04/03/2015 80,243 MI
Bumper to Bumper Limited Warranty 04/03/2007 243 MI 04/03/2010 36,243 MI
Emission Select State Component Lty Wty 04/03/2007 243 MI 04/03/2014 70,243 MI
Powertrain Limited Warranty 04/03/2007 243 MI 04/03/2012 100,243 MI
Special Coverage 09239 04/03/2007 243 MI 04/03/2017 100,243 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
09/08/2010 150474 ZFAT----Field Action Recall V2283 - 10153-Windshield Washer Solvent Heater Asm Removal - No Check Issued (Veh in Dlr New/Used Inventory) 54,200 MI
12/30/2008 165722 ZREG----Regular Vehicle Transaction N2131 - Door Lock and Side Window Switch Replacement - Driver Side 28,971 MI
12/23/2008 165607 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 28,692 MI
10/16/2007 052424 ZREG----Regular Vehicle Transaction B4156 - Outside Rearview Mirror Replacement - Left Side 8,255 MI
09/18/2007 051354 ZREG----Regular Vehicle Transaction R4490 - Remote Control Door Lock Transmitter Replacement 7,697 MI
02/08/2007 190503 ZREG----Regular Vehicle Transaction Y0151 - 07007- Service Update - Reprogram BCM, RCDLR, and RKE Transmitters 2 MI
12/16/2006 188709 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 2 MI
06/05/2006 A86423 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
doubletapdrew
Drew, 1GYUKHEF5AR159630. Thanks in advance.
Vehicle Information
VIN: 1GYUKHEF5AR159630 Model: 6K10906-2010 ESCALADE ESV AWD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Customer Satisfaction Program N120138 12138 TRANSMISSION DIPSTICK TUBE FRACTURE 10/24/2012 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: 6NG842C4 XM Status: Active
Corrosion Limited Warranty 03/11/2010 44 MI 03/11/2016 Unlimited
Emission Select Component Ltd Wty 03/11/2010 44 MI 03/11/2018 80,044 MI
Powertrain Limited Warranty 03/11/2010 44 MI 03/11/2015 100,044 MI
Special Coverage 11273 03/11/2010 44 MI 03/11/2020 120,044 MI
Bumper to Bumper Limited Warranty 03/11/2010 44 MI 03/11/2014 50,044 MI
Service Contract
03/22/2013 302660 ZFAT----Field Action Recall V2644 - 12138 - Install Transmission Filler Tube Damper 55,183 MI
03/22/2013 302660 ZREG----Regular Vehicle Transaction T5876 - 11273 - Throttle Position Sensor Cover Replacement and ECM Reprogram (inc diagnosis) 55,183 MI
08/09/2012 290597 ZREG----Regular Vehicle Transaction R5554 - Video Display Replacement 50,199 MI
07/10/2012 5731758 ZREG----Regular Vehicle Transaction R5541 - Player, Video Entertainment System - Assembly Return to ACDelco ESC 46,946 MI
08/06/2011 I61124 ZREG----Regular Vehicle Transaction Z2082 - ROADSIDE SERVICE (FUEL DELIVERY) 27,000 MI
10/11/2010 252665 ZREG----Regular Vehicle Transaction C3342 - Front Side Door Upper Trim Panel Replacement 12,231 MI
10/11/2010 252665 ZREG----Regular Vehicle Transaction D1439 - Instrument Panel Center Air Outlet Deflector Replacement 12,231 MI
10/11/2010 252665 ZREG----Regular Vehicle Transaction C2706 - Front Floor Console Compartment Door Panel Replacement 12,231 MI
03/29/2010 240750 ZREG----Regular Vehicle Transaction B2858 - Sunroof Panel/Window Garnish Molding Replacement 961 MI
01/21/2010 A59630 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
GMCaldwell
Hello Drew. I'm looking at buying a used Tahoe. Can you please help me out?
1GNFC23099R293180
Thanks!
doubletapdrew
Hi Drew any chance you can get this one as well? 1GKUKEEFXAR288195
Thanks!!
Vehicle Information
VIN: 1GKUKEEFXAR288195 Model: TK10706-2010 YUKON 1500 4WD
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: Yes
Branded Title
Warranty Block
Service Information
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: XLDN728L XM Status: Active
OnStar Vehicle Diagnostics: Y DMN Enabled: Y
Emission Select State Component Lty Wty 10/16/2010 321 MI 10/16/2017 70,321 MI
Powertrain Limited Warranty 10/16/2010 321 MI 10/16/2015 100,321 MI
Corrosion Limited Warranty 10/16/2010 321 MI 10/16/2016 100,321 MI
Emission Limited Warranty 10/16/2010 321 MI 10/16/2013 50,321 MI
Bumper to Bumper Limited Warranty 10/16/2010 321 MI 10/16/2013 36,321 MI
Emission Select Component Ltd Wty 10/16/2010 321 MI 10/16/2018 80,321 MI
Service Contract
Policy Number: 818545869 Owner: PAULSEN
Description: GMPP 72/72 MAJOR GUARD Deductible Amount: 0.00
Effective Date: 10/16/2010 Expiration Date: 10/16/2016
Effective Odometer: 322 MI Expiration Odometer: 72322 MI
Daily Rental Limit: 35.00
03/04/2014 519178 ZSCT----Service Contracts 2441580 - Power Vacuum Brake Booster Replacement 54,243 MI
03/04/2014 519178 ZSCT----Service Contracts 2440100 - Master Cylinder Replacement 54,243 MI
01/29/2013 504951 ZFAT----Field Action Recall V2644 - 12138 - Install Transmission Filler Tube Damper 37,025 MI
12/13/2011 488143 ZREG----Regular Vehicle Transaction J5490 - Throttle Body Assembly Replacement 18,606 MI
06/30/2010 A88195 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
---------- Post added at 10:52 AM ---------- Previous post was at 10:51 AM ----------
1GNFC23099R293180
Thanks!
Vehicle Information
VIN: 1GNFC23099R293180 Model: CC10706-2009 TAHOE 4X2 LT
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: 26A142W0 XM Status: Active
Bumper to Bumper Limited Warranty 10/21/2009 14 MI 10/21/2012 36,014 MI
Powertrain Limited Warranty 10/21/2009 14 MI 10/21/2014 100,014 MI
Corrosion Limited Warranty 10/21/2009 14 MI 10/21/2015 100,014 MI
Emission Select Component Ltd Wty 10/21/2009 14 MI 10/21/2017 80,014 MI
Service Contract
11/28/2011 510215 ZREG----Regular Vehicle Transaction E2320 - Front Wheel Bearing and Hub Replacement 33,065 MI
11/28/2011 510215 ZREG----Regular Vehicle Transaction J7949 - Remove and Replace Throttle Position (TP) Sensor Cover 33,065 MI
11/28/2011 510215 ZREG----Regular Vehicle Transaction Add Credit E2327 - Front Wheel Bearing and Hub Replacement - Both Sides 33,065 MI
11/28/2011 510215 ZREG----Regular Vehicle Transaction Full Debit - Reversal E2327 - Front Wheel Bearing and Hub Replacement - Both Sides 33,065 MI
11/28/2011 510215 ZREG----Regular Vehicle Transaction E2327 - Front Wheel Bearing and Hub Replacement - Both Sides 33,065 MI
03/30/2010 448934 ZREG----Regular Vehicle Transaction R4490 - Remote Control Door Lock Transmitter Replacement 4,664 MI
03/30/2010 448934 ZREG----Regular Vehicle Transaction B4379 - Front or Rear Side Door Latch Striker or Lock Striker Replacement 4,664 MI
03/30/2010 448934 ZREG----Regular Vehicle Transaction B1785 - Arm, Wiper - Back Glass - Replace 4,664 MI
09/29/2009 A93180 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
GMCaldwell
Thanks Drew, one more if you don't mind. I'm trying to decide the 2 Tahoes.
1GNUKBE08AR146893
Thank you!
Jhawk79
