service history from vin#?
doubletapdrew
Thanks Drew, one more if you don't mind. I'm trying to decide the 2 Tahoes.
1GNUKBE08AR146893
Thank you!
Vehicle Information
VIN: 1GNUKBE08AR146893 Model: CK10706-2010 TAHOE 1500 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 50 - FLEET
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N120138 12138 TRANSMISSION DIPSTICK TUBE FRACTURE 10/24/2012 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: HEA642W0 XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Corrosion Limited Warranty 12/22/2009 0 MI 12/22/2015 100,000 MI
Emission Select Component Ltd Wty 12/22/2009 0 MI 12/22/2017 80,000 MI
Bumper to Bumper Limited Warranty 12/22/2009 0 MI 12/22/2012 36,000 MI
Powertrain Limited Warranty 12/22/2009 0 MI 12/22/2014 100,000 MI
Special Coverage 11273 12/22/2009 0 MI 12/22/2019 120,000 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
01/10/2013 202794 ZFAT----Field Action Recall V2645 - 12138 - Replace Transmission Filler Tube 83,255 MI
01/10/2013 202794 ZREG----Regular Vehicle Transaction T5876 - 11273 - Throttle Position Sensor Cover Replacement and ECM Reprogram (inc diagnosis) 83,255 MI
12/28/2011 L31352 ZREG----Regular Vehicle Transaction Z2083 - ROADSIDE SERVICE (BATTERY/JUMP START) 61,000 MI
11/29/2010 311151 ZREG----Regular Vehicle Transaction B5933 - Liftgate Strut Replacement 28,882 MI
11/12/2010 12994 ZREG----Regular Vehicle Transaction N6654 - Connector Reconnection 28,549 MI
12/23/2009 A46893 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
Koop
Hey Drew can you run this vin number
VIN number: 2007 Yukon Denali XL
1GKFK66827J148065
Thanks a million
doubletapdrew
1GKFK66827J148065
Thanks a million
Vehicle Information
VIN: 1GKFK66827J148065 Model: TK10906-2007 YUKON XL 1/2 TON - 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: H6WVH0MV XM Status: Active
Corrosion Limited Warranty 05/08/2006 7 MI 05/08/2012 100,007 MI
Emission Select Component Ltd Wty 05/08/2006 7 MI 05/08/2014 80,007 MI
Special Coverage 09239 05/08/2006 7 MI 05/08/2016 100,007 MI
Bumper to Bumper Limited Warranty 05/08/2006 7 MI 05/08/2009 36,007 MI
Powertrain Limited Warranty 05/08/2006 7 MI 05/08/2011 100,007 MI
Service Contract
02/28/2011 783465 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 95,144 MI
03/09/2009 698708 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 55,344 MI
01/15/2008 645019 ZREG----Regular Vehicle Transaction B9641 - Lamp Assembly, Exterior - Stop, Tail And Turn Signal - Left - Replace 29,148 MI
01/15/2008 645019 ZREG----Regular Vehicle Transaction R9707 - Navigation Radio, Reprogram 29,148 MI
01/15/2008 645019 ZREG----Regular Vehicle Transaction C9289 - Cover/Bezel And/Or Guide, Seatbelt - Replace 29,148 MI
01/15/2008 645019 ZREG----Regular Vehicle Transaction N6642 - HVAC System Wiring and/or Connector Repair or Replacement 29,148 MI
12/19/2007 641855 ZREG----Regular Vehicle Transaction K5220 - Lever, Shift Control (At Transmission) - Replace 27,595 MI
12/19/2007 641855 ZREG----Regular Vehicle Transaction F9995 - Customer Concern Not Duplicated (CCND) - Driveline/Axle 27,595 MI
12/19/2007 641855 ZREG----Regular Vehicle Transaction B9640 - Lamp Assembly, Exterior - Stop, Tail And Turn Signal - Right - Replace 27,595 MI
12/19/2007 641855 ZREG----Regular Vehicle Transaction B7289 - Headlamp/Composite Assembly - Left - Replace 27,595 MI
12/19/2007 641855 ZREG----Regular Vehicle Transaction B4280 - Front Side Door Inside Handle Replacement 27,595 MI
12/19/2007 641855 ZREG----Regular Vehicle Transaction Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 27,595 MI
08/01/2007 624274 ZREG----Regular Vehicle Transaction C4283 - Rear Window Lower Garnish Molding Replacement 15,514 MI
07/02/2007 620120 ZREG----Regular Vehicle Transaction Y0152 - 07033 - Service Update - Reprogram BCM 13,477 MI
07/02/2007 620120 ZREG----Regular Vehicle Transaction K6560 - Valve Body, Transmission - R&R Or Replace 13,477 MI
12/20/2006 596183 ZREG----Regular Vehicle Transaction C4283 - Rear Window Lower Garnish Molding Replacement 6,979 MI
12/20/2006 596183 ZREG----Regular Vehicle Transaction R4490 - Remote Control Door Lock Transmitter Replacement 6,979 MI
05/08/2006 T68880 ZTPT----Transportation Transactions C3541 - Rear Side Door Trim Panel Replacement - Left Side 3 MI
05/08/2006 567780 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 3 MI
04/11/2006 A48065 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
fastlowchevy
Drew can you run the service report for this vin.
Vin:1gkfk13077j229323
2007 Gmc Yukon
Thanks!
doubletapdrew
2007 Gmc Yukon
Thanks!
Vehicle Information
VIN: 1GKFK13077J229323 Model: TK10706-2007 YUKON 1500 4WD
Service Update Bulletins N060162 06162 SERVICE UPDATE-INVENT/CUST VEHS E85 VFFS UPDATE REPGM ECM *EXPIRES 8YR/80K MI* 12/12/2006 Closed
Service Update Bulletins N070007 07007 SERVICE UPDATE - REMOTE KEYLESS INOP/BATT LOW-GMT900 ONLY-*EXP W/BASE WARR* 02/06/2007 Closed
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: XAR9L0WA XM Status: Active
Corrosion Limited Warranty 09/05/2006 320 MI 09/05/2012 100,320 MI
Emission Select Component Ltd Wty 09/05/2006 320 MI 09/05/2014 80,320 MI
Bumper to Bumper Limited Warranty 09/05/2006 320 MI 09/05/2009 36,320 MI
Powertrain Limited Warranty 09/05/2006 320 MI 09/05/2011 100,320 MI
Special Coverage 09239 09/05/2006 320 MI 09/05/2016 100,320 MI
Service Contract
03/26/2010 088396 ZREG----Regular Vehicle Transaction Y0124 - 06162 Product Enhancement - Engine Control Module Reprogram with SPS 45,485 MI
03/26/2010 088396 ZREG----Regular Vehicle Transaction Y0150 - 07007- Service Update - Reprogram RCDLR and RKE Transmitter 45,485 MI
07/30/2009 316430 ZREG----Regular Vehicle Transaction N6642 - HVAC System Wiring and/or Connector Repair or Replacement 34,908 MI
08/28/2006 263495 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 2 MI
08/14/2006 A29323 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
doubletapdrew
could I get some info on this vin# please
1GKFK668X8J172101
Thanks a lot
Vehicle Information
VIN: 1GKFK668X8J172101 Model: TK10906-2008 YUKON XL 1/2 TON - 4WD
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: URZUW0C9 XM Status: Active
Special Coverage 11273 01/05/2008 12 MI 01/05/2018 120,012 MI
Powertrain Limited Warranty 01/05/2008 12 MI 01/05/2013 100,012 MI
Bumper to Bumper Limited Warranty 01/05/2008 12 MI 01/05/2011 36,012 MI
Emission Select Component Ltd Wty 01/05/2008 12 MI 01/05/2016 80,012 MI
Corrosion Limited Warranty 01/05/2008 12 MI 01/05/2014 100,012 MI
Service Contract
Policy Number: 817244069 Owner: DONNELL
Description: GMPP 60/100 MAJOR GUARD Deductible Amount: 100.00
Effective Date: 01/05/2008 Expiration Date: 01/05/2013
Effective Odometer: 12 MI Expiration Odometer: 100012 MI
Daily Rental Limit: 35.00
03/06/2012 0189736 ZSCT----Service Contracts E5960 - Air Compressor Replacement 92,239 MI
02/09/2012 0189256 ZSSP----Special Sales Programs Z2368 - Free LOF Offer for Jan/Feb 2012 Chevy 91,665 MI
08/16/2011 0186135 ZSCT----Service Contracts N2440 - Switch - Stop Lamp - Replace 87,122 MI
08/16/2011 0186135 ZSCT----Service Contracts J7928 - Remove and Replace Revised EVAP CVS Valve Assembly and Jumper Harness 87,122 MI
07/07/2010 103755 ZREG----Regular Vehicle Transaction E2321 - Bearing And Hub Assembly, Front Wheel - Left - Replace 76,769 MI
07/07/2010 103755 ZFAT----Field Action Recall V2281 - 10153-Windshield Washer Solvent Heater Asm Removal and Issue Check to Customer (Cust. Vehicles Only) 76,769 MI
12/09/2009 234349 ZSCT----Service Contracts J3100 - Radiator Replacement 67,834 MI
12/09/2009 234349 ZSCT----Service Contracts C0183 - Front Side Door Window Regulator Replacement - Left Side 67,834 MI
12/09/2009 234349 ZSCT----Service Contracts Z7901 - 1-DAY COURTESY TRANSPORTATION 67,834 MI
10/08/2009 561174 ZSCT----Service Contracts B4521 - Rear Side Door Outside Handle Replacement - Left Side 65,169 MI
10/08/2009 561174 ZSCT----Service Contracts B4120 - Front Side Door Outside Handle Replacement 65,169 MI
03/26/2009 550305 ZSCT----Service Contracts J6372 - Sensor, Oxygen (Engine Control) - Replace 46,359 MI
03/26/2009 550305 ZSCT----Service Contracts H2494 - Switch, Pressure (ABS) - Replace 46,359 MI
10/17/2008 325440 ZREG----Regular Vehicle Transaction B4520 - Rear Side Door Outside Handle Replacement 27,368 MI
11/29/2007 A72101 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
farhanm
Oklahoma City
Drew could I trouble you for one more vin#. I saw this 2009 slt with less mileage that I wanna check.
VIN: 1GKFK36319R169464
Thanks a lot again!
doubletapdrew
Thanks a lot again!
Vehicle Information
Branded Title
Warranty Block
Service Information
Service Contract
GunRunner7
Banned
Drew,
Could I twist your arm to check this VIN for me please. Thank you for providing us this information, it is very generous of you. Thanks again!
1GNSKJE70ER198619
iamdjgad29
