Shifter
Da90
Tulsa, OK
Can the tip of the shifter be removed ? I was just wondering
I'm not sure if you can remove the tip of the shifter or not. I know the rubber part can be removed.
How easy is it to screw in, mine's loose as hell from my hand resting on it
If I remember right there is a bolt with a star head on it right under the shifter boot. You might try and tighten that up?
bsamoul
Hoe Enthusiast
Walnut Creek, CA
I'll do that, thanks!
