Shocks and questions
Big Mama
Virginia
Good to go with GM or AC Delco. How were the rear shocks? You can always go up in size on the sway bar and end links.
Cucv
Cucv
Pdx
He said rears are fine, they are the Arnott replacement, there are like 10 options on rock auto for shocks for the front. How do i know what to get.
Rivelite
Chicago, IL
If your going to do the inner/outter tire rods, hubs, end links, you may as well do your idler arm, idler arm bracket, the dreaded pitmarm arm and new sway bar bushings. I ordered all Moog parts for this. This should take care of about any steering issue you have outside of a worn steering box or uneven tires. I had very loose steering myself and decided to just replace all the same worn parts and it made a huge difference.
