WeekenderNutJob
- Joined
- Dec 27, 2022
- Posts
- 17
- Reaction score
- 20
I have a 6.2 on a 2008 Denali. Pretty sure it has VVT. Trying to diagnose a low oil pressure on 232,000 mi . No knocks no check engine oil light. I've installed AC Delco sending unit and screen. Still low. Using a wix gold filter and 5W30 high mileage synthetic. Warm Idle pressure is at maybe 10 or less maybe even as low 7 PSI.... which seems scary to me. My next best guess is the pickup tube o-ring or bypass relief valve or the pump und spring. Which fom my understanding all require the removal of the pan. I have a all-wheel drive and so it's going to be a pain to do for a bit and I'm not going to get to for a month or more.
What would you do for a short-term fix? Thicker oil like a Lucas oil stabilizer? I've also read that adding an extra quart or two of oil may temporarily put the o-ring under enough oil that it actually sucks, if that's the issue. I don't know much history on this car. I just purchased it.
I've read posts for about the last hour and I'm not finding a good all-in-one, while you're in there fix this also type of thread for dropping the oil pan. Does anybody have a good list?
Assuming it's going to be a month or two before I can get to it. What are the best short-term fixes?
Oil pressure when it's driving seems to be around 25-40. It mostly just drops really low when I'm sitting at a light. Oil pressure climbs basically about 10 psi for each 1000 rpm.
