Show off your 2015+ leveled Tahoes and Yukons!
Oh Kee Pah
MAINE
Looking good! Well done on the overland build. More mods planned?
Have you used the onboard air compressor? What are you airing down to off trail?
Also - what's that running board you've got there? A little hard to tell, but it sure doesn't look like OE...
Safe Travels!
2” front level with 1” rear spacer. 275/70r18 on fuel rebel 6 18x9 with -12 offset.
Tahoe_Rx
Safe Travels!
Yes, I have an ARB compressor mounted in the spare battery tray under the hood. Have an 8 gang aux beam switch near the headlight control on the dash to control light cubes, light bar, reverse lights and air. The brush guard is from Steelcraft. I will have to look back through emails to find who made the side steps. But I have had them on for a couple years and have been very pleased.
Tahoe_Rx
Safe Travels!
Also planning to change out my spacer leveling kit for the Cognito/Fox 3” lift/level kit. It uses new UCAs and Fox 2.0 coilovers and rear struts. Hope to have the suspension changes done in the next month or so
Tahoe_Rx
Also - what's that running board you've got A little hard to tell, but it sure doesn't look like OE...
Safe Travels!
This is the link to the side steps. I had low expectations given the price but took a shot because I hated the plastic OE steps. I have had them on for 2 years now with no issues. Sturdy, no rust, no chips on coating and plenty strong for my use as this is obviously not a rock crawling rig.
Tahoe_Rx
Just had the Cognito 3” lift installed with Fox 2.0’s and man is it sweet. Ride quality is incredible. I regret not doing it sooner. I will upload some photos tomorrow when it is light out.
I had a 2” level installed before (spacers with stock struts). Not sure if my factory coilovers were just worn out and it had basically settled back to a stock height or what. Because I actually gained 2.5”-3” of lift compared to my stance with the spacers. I measured from ground level o top of wheel well through the center of the wheel. It sat at 38” high with the 2” spacers. Now after switching to the fox coilovers from Cognito it is measuring just under 41”.
olyelr
Elk Rapids, MI
Pics or it didnt happen lol jk.
What did you do for the rear?
stormtrooper777
