Which ones did you use?
Interior lights
http://r.ebay.com/iYRCom
Fog Lights
http://r.ebay.com/JKXPHj
Reverse Lights
http://r.ebay.com/yRxuWU
I really need one of these kits. How you do the center console light?I think I have the same kit as @yukonoffroad27 The Type S LED Bluetooth Kit. It has an app where you can change up to 4 zones and add extensions all over the place. I have 3 zones right now: Front Floorboards, Center Console, and Rear Floorboards. I have them set to a kind of turquoise blue that matches the gauges pretty well, but you can change the color to anything you want. Not only that, but all 4 zones can be different. (The blue and red in the pics is just to show them off better) I might go with some puddle or rock lights one of these days.
For the console, I just drilled a hole about the size of the led pod above the cubby hole and used some heavy duty tape to secure it. And you can add 4 zones, but as many extensions as you want to each zone. It's a pretty cool design as far as wiring goes.I really need one of these kits. How you do the center console light? View attachment 192521
Can you add more strips and use the same controller ?
Nice. Thanks for the info. I added a light in the same spot along with the rear cup holders. At night every person that sits in the 2nd row is always looking for where the dammed cup holders are at lolFor the console, I just drilled a hole about the size of the led pod above the cubby hole and used some heavy duty tape to secure it. And you can add 4 zones, but as many extensions as you want to each zone. It's a pretty cool design as far as wiring goes.
Awesome idea. They make some rock lights too that might be my next project.Nice. Thanks for the info. I added a light in the same spot along with the rear cup holders. At night every person that sits in the 2nd row is always looking for where the dammed cup holders are at lol
Nope, strivgly plug and play. Nothing to do with the dimmer. Did you get the right size? Gotta be careful with those contacts. Touch the wrong ones together and you'll blow the fuse. Did you check that?Yesterday I replaced my interior lights with LED's as many have. Easy peasey except for the map lights which took more time than all the others combined. Fiddly job..the reflectors wanted to go in cockeyed. But with uncharacteristic patience I got them done.
I really like the result. But..didn't work in the vanity mirror lights. couldn't get them to come on. Is the dimmer the issue?
