my 2012 Tahoe with 6 speed transmission is very sluggish when accelerating around corner especially. Changed max air flow sensor but no help. Runs fine cruising. Should I suspect fuel injectors or spark plugs next?
Transmission issue sorry..
I had a loaner impala 3.9 it was real sluggish in the 1 and 2nd gears you could pretty much floor it and it was still sluggish it was like driving a daewoo 3 banger and trying to race in it. (did not slip but something was off) the 0-60 was about 16 seconds lol
once in 4th,5th and 6th gear were fine..
I had a 5.3L Tahoe XFE with 6 speed ( title issue and return)
I did not feel this sluggishness you talk about.. 110k miles
on my hybrid i did feel it occasionally" sluggishness"(not talking about autostop lag) but everything was normal once I cleaned the battery terminals and resit them correctly and tight (that actually fixed all of my electrical problems including autosop/start lag from the Aux transmission pump)
it could also be a traction control issue that is something i would investigate
that could slow down the engine/transmission as well
I would start off with the battery connections and check them make sure they are nice and tight and clean terminals
If you watch scotty kilmer he says to check the cheapest and simple things first then work your way to the expensive items..
That is why I checked my 12V battery first before buying a replacement Aux pump that would have cost me over 600$ to replace for nothing
