Sprint booster?
L
lynxnova
New Jersey
Vitesse or sprint booster...which one is a scam?
Sent from my SM-G920V using Tapatalk
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
They just trick your PCM into thinking you are giving more throttle than you are. So if you give 25% throttle, it tells the PCM to open it 50%. A tuner can do the same, but it really isn't the best solution. If you want more power, you should look into cam/headers/blower, rather than wasting money on this.
08grey
I've installed sprint boosters they are exactly what Jenna said. They just make your pedal more sensitive. It can be dialed up or down 4 steps. It's snake oil. Don't waste your hard earned money. Get real performance mods or a tune.
Fish-man
It also gets rid of the lag. Scam? Snake oil? I'm thinking that since they do what they say, there's no deception here.
With a tune, it can leave a "trace" if you are worried about warranty. With this, you can simply remove hardware...in 2 minutes.
With this, you can adjust the sensitivity for slippery conditions...with a tune, you are stuck with whatever your tuner guy plugged in.
I cannot speak for the sprint version, but the vitesse works to my satisfaction. I am also looking into a custom tune, but will be looking for someone who will work with & around the throttle controller.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Tuners can also can also perform this function within a tune, no need for something separate.
Sent from my fone.
08grey
It describes what it does as a performance change or a economy mode. That's why it's snake oil to me. Get a tune. Adjusting shift points and pressures will make you way more satisfied for you dollar.
Fish-man
knock it or try it. Vitesse was offering a 30d money back guarantee... at least when I bought mine just over a month ago, you can check with them. And no I did not send it back. When I get a custom tune (only running a canned tune via inTune... with adjusted shift points/pressure), I will plan on keeping it on the vehicle for the sake of INSTANTANEOUS on-the-fly adjustability ...nobody's tune can do that. I do dial it back for use on wet roads... and will have to for snow as well. Take a look over at camaro5.com for reviews.
