Starter issues. ..
biggjim313
biggjim313
Detroit
Okay back on this again. .. Was out of town and just came back and now I'm workin on this again.. Had the starter rebuilt and put it in and now it's trying to start like it should and not just cranking away but now it starts and then dies right out.
biggjim313
biggjim313
Detroit
The alarm is the Python 5710p I believe. And also I let the key sit forward for 15 minutes and then it started. I did notice that the security light was on and then it turned off after letting the key sit forward. . Also did notice that my radio sometimes is not turning on too.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i am looking up details on alarm now. for can you check the fuse for the radio. if is is intact put a meter on the fuse block. neg-ground it somewhere, pos-try probing both terminal on the fuse block with the key on and also in key acc position.
---------- Post added at 03:46 PM ---------- Previous post was at 03:31 PM ----------
apparently you can disable the remote starter thru a toggle switch or valet mode. that would keep the relay built in from actuating but does not preclude it being damaged inside. i was gonna have you disconnect a wire that would narrow the issue much faster but i can't seem to find a diagram yet for the alarm.
biggjim313
biggjim313
Detroit
Definitely appreciate the help brotha.
biggjim313
biggjim313
Detroit
Well now the radio is working again but I can't get the truck to start. .lol.. tried letting the key sit forward for a few times for like 20 minutes or so.
---------- Post added at 08:57 PM ---------- Previous post was at 08:45 PM ----------
Ha.. got it started and now the radio is still working but my hvac controls seem to be iffy.
SunlitComet
OBS Jedi-Do Good
when the radio was down were the wipers too? with hvac controls goofed do the rear brakes lights work correctly when pedal is depressed or do they look week in some way?
biggjim313
biggjim313
Detroit
Not sure if the wipers were down but I believe the brake lights seem to be fine.
---------- Post added at 02:55 PM ---------- Previous post was at 02:50 PM ----------
My alarm is actually the Python 991 responder lc3 sst.
etreanor
