Stock rear camera with aftermarket head unit
tazjamin
tazjamin
Casa Grande, Az
Well one other thing not working is the steering wheel controls but I think I just need to re flash the maestro or it might be that I plugged the wire in the wrong spot because I believe the steering wheel controls are through a headphone jack or aux jack and I have two or three of those in the back of the radio not sure but I will try a few things to try to get this to work but I know the rear camera works it just doesn't work correctly when I have the camera view on or off
TahoeLT10
You have three because most likely 1 for Aux In, 1 for Aux out, and 1 for SWC (remote).
tazjamin
tazjamin
Casa Grande, Az
Well I got the steering wheel controls working it was the W/R jack now I think I'm going to have to call pioneer on the rear camera part
TahoeLT10
Let me know what they say. I am trying to re-wire my camera harness so I can turn it on while driving forward as well.
tazjamin
tazjamin
Casa Grande, Az
What if you wire a switch to your reverse wire so you have two wires connected to the radio harness reverse wire. One from your reverse and one from the switch that way you hit the switch and it turns on, that way your reverse will work and you can manually turn it on. The pioneer radio is already made for the camera to be on all times if you want
TahoeLT10
That's what I am doing but after testing yesterday I found out that camera input when in reverse is ~2.5v and there are no wires anywhere near that provide CONSTANT 2.5v. This means I need to convert from 12v that I was able to find to 2.5v and thats where ML317 or DC to DC step down will take place. Now that is solved, if I do just that it means that the CONSTANT current that is always connected will also flow back to the back up lamp and whatever other modules it might be passing through. So I just now realized that I will have to add two diodes to BOTH the constant + and reverse + that way current from each does not interfere with the current from the other.
---------- Post added at 04:58 PM ---------- Previous post was at 04:54 PM ----------
Something like this:gepedyde.jpg
tazjamin
tazjamin
Casa Grande, Az
Wow nice!! Yeah that sounds like the only way to me is to add another power source to it
---------- Post added at 10:55 AM ---------- Previous post was at 10:07 AM ----------
So I heard from idatalink about the radio and the firmware has not been released yet i just love it how pioneer says its compatible and maestro says the same thing but yet the only thing they have working is the steering wheel controls
Avy2010
Dallas tx
Back up camera
How do you get the back up camera to work i have a pioneer 4500 do you need a harness?
jrmhokie
