Sometimes the weights will come off. I would definitely inspect the tires and wheels, make sure no bubbles in tires or tread seperation
Will do 1st thing in the AM..also if that was the case it should do that on smooth roads right ???
^^^yes
See this is were I'm lost on smooth roads for example highway the ride is smooth no shaking at 50mph or anything
This could be suspension related then. I had a similar issue with my Grand Prix not long ago. I took a look and noticed that my sway bar end links were worn so I replaced them with a set of Moog sway bar end links and the issue went away.
based on your last post I'd say it's not tire or wheel related now.
Same here that was just an option cause the wheels an tires are brand new only have 2k on them .. Has anyone change there struts/shocks on a 5 year old chevy/gmc truck because ride quality or blown issues ???
+1
---------- Post added at 12:35 AM ---------- Previous post was at 12:33 AM ----------
I put belltech's lowering struts on the front of my 08 Av with 27000 miles
Did u replace strut due to damage factor or just for the hell of it
