Struts or rims
06xl
06xl
MD
Whats is a good brand for stock height suspension set up
06xl
06xl
MD
Any1 else change there struts any input on performance
2005yukonxl
do you still have yoru stock rims? if so, bolt them up. it could be the low profile tire you are using or if the rims arent hub centric they could be off just a bit...i know the tundra world has an ongoing issue with some aftermarket rims being fine one moment and then shaking all over the next. i'd swap wheels/tires and drive it to see if its a suspension issue or just a tire/wheel issue. it could be that all is as good as its going to be, running low pro tires will cause alot more vibration and bumps to be felt...just nature of the beast.
06xl
06xl
MD
Well my stock rims have ****** tires on them so that won't help at all im staring to think it's the struts because if I hit a bump it feels like the tires bounce of the ground alittle
Ja1034
