Sub placement?
1dopeHoe
Typically subs in an SUV sound best aimed up with the port of the box facing the rear.
SLT Kon-Man
Southwest Alabama
I think it depends on the type of enclosure that you are using, a sealed enclosure does not have ports so directional placement should not be an issue, and if I'm not mistaken low frequency (bass) is non-directional, so placement should not matter in either case...
LG Customs
Stockdale, Tx
i've had them both ways and the best way is facing the rear so they can bounce off the back door it hits much harder
the big blue bus
richmond, va
what they have all said. i put subs in my sisters jeep and its a ported box with 2 12s. sounds real nice aimed at rear hatch, you get the bass bouncing all around inside instead of in the seat
LILC509
Depends upon your subs. Like for example I have the new Orion HCCA's and they need to be facing straight up or straight down according to Orion. If you face them to the back or the front you may or will cause damage to the voice coil. It doesn't hurt to call the manufacture to find out.
BruceWayne
