Supercharged Tahoe TBSS
sumo
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I got my Pulley from blackbear. I'm running 93 octane without any problems. I using the injectors that came with the supercharger
sumo
sumo
rhode island
After waiting a month for the rr rotor, I was finally able to finish my brake upgrades. The only thing I have left to tackle is the mid lines on the rear. They run above the axle. Soaked them in kroil and save those for another day.
As far a braking. It's really nice. There isn't really any pedal travel anymore and the pedal is really firm. They still look small and maybe another upgrade to bigger in the future. But for now, I'm really happy with this set up.
08grey
I just noticed on the brake line pic. Why haven't you cut the bump stop bracket off yet?
sumo
sumo
rhode island
One of these days maybe. I never had any problems back there. I'm lowered 3 in the rear any have helper bags at 10 psi. I couldn't find a spacer that I was happy with. Before it was either looking to low in the rear cali lean look even though it was slight or too high. With the bags I could air up or down and find angle I was happy with.
Tegra1027
North chicago burbs
Niiiuce build. I have a few questions for you..
What did this cost you?
Did you have to upgrade oil pump or fuel system?
What can the stock engine handle?
TIA
gat0r
DFW
where did you install/position your wide band sensor?
sounds great
sumo
sumo
rhode island
TIA
Haven't tallied the numbers but just the cost of parts because I did all the labor myself.
No oil pump upgrade needed, injectors that come with supercharger is enough to support 7-10 psi. Maybe more but I was told may need to switch to methonal to achieve more
sounds great
Rear o2 are disabled I put the wb in the driver side rear o2 as cyc 5 and 7 seem to be the most problematic and fail. Moutning to wb here I can monitor if that side starts running lean.
I plan on using the pass rear o2 and adding another wb for that side
CaptPat
