Dismay
yeah it looks like the only way to get the proper rear end links is to buy the kit with the brackets for 160 dollars
where did you get them?
Where did you see to flip the sway bar (Couldn't find the thread)?? I'm about to add shorter links and will probably run into the same problem.so I think I might have a solution?
flip the sway bar over so its underneath the tie rod
I can already feel the difference its a LOT stiffer in the front and I lost all my steering wobble I used to have as well as it brought my wheels back almost to 0º camber
best $20 I have spent so far and the installation was VERY easy.. just read over the eibach sway bar install (can't remember the members name) and went out and did it
How do i tell if they are for front or rear. I know there is a part number above, but is that for just djm or stock part? Also, does energy make the rear too? what number would that be?
Djm make the front also?
