Tailgate and rear window not locking
CWARE
Norman,Ok
Yesterday I noticed they both were not locking. They worked prior to this fine as far as I knew. I tried both the remote and the lock buttons inside the vehicle and nothing works. I also checked the fuses for the locks but all were fine. My vehicle is a 06 Denali. Any ideas?
chauncey0337
MLT, WA
Have you tried locking with the key? If it locks by turning the key, then it's probably the actuator(not sure if that's the correct term). If not maybe something came loose. You can access the tailgate lock by removing the rear panel. You can pop it off, it's just held in place by those compression clips.
CWARE
CWARE
Norman,Ok
I wasn't aware that the tailgate could be locked by key. I just tried it and turning the key in the driver front door only locked that door.
CWARE
CWARE
Norman,Ok
Just took the panel off and everything looks connected like it should be.
afpj
Isn't there a keyhole on the rear liftgate? My 02 Yuk has one, but I don't know about the 06 Denali.
Did you take a VOM to the connectors and see if there's power going to the actuators when you hit the button? Just thinking out loud.
CWARE
CWARE
Norman,Ok
Nope not key hole on my 06. I'll have to get a voltmeter and check that tomorrow. I'm just wanting to see if there is power going into the actuator correct? Any particular spot?
Trackerdude
2005 Yukon - same problem
Hve you found a fix yet? Mine started doing the same thing this week.
gtwhoa
my 05 yukon is doing that too - except it wont unlock. Any updates?
picinisco
Gilbert, AZ
my 05 has the same problem. the black actuator is the problem. The dealer does not sell this on its own. Need to buy the entire lock mechanism for $380. Ripoff. You can remove the slider from the actuator and leave the door locked or zip tie it in place allowing the door to open and close but not lock.
gtwhoa
I took the panel off mine and checked the actuator conncetion, I get a momentary 12v at the connector when unlocking and locking so it must be the actuator. I ordered a used one on ebay for $60 hopefully it'll work.
beka1283
