Tech 2 Purchase
Should the light on the Candi module be lit at all times?20201024_145006.jpg
It lit up for a sec then didn't anymore.
Bandit-66
I got the VCX Nano from UK about 4 weeks ago and wanted to send it back first because it did not work. Problems with the license and it did not want to run.
Then I communicated with the Chinese via Whats App and then they made it work with a remote function.
Then I tested it on our 2000 Blazer, because many people in our forum in Germany wanted to know if it can do ABS Bleeding,
After that I tested it on our 2015 Tahoe and got into all the options and also found a bug in the airbag, which was reported to me a week before by a Chevy dealer in Berlin, during a recall program.
I also made 2 small videos where you can see that it works, unfortunately they are in German.
yes they work, getting the software setup correctly is tricky at best. sometimes it doesn't work after you get it setup and then they update it and it works, and then sometimes they update and it stops working. so once you have it set and working, DO NOT update it unless it stops working. if it shows there is a update available and it is still working just ignore the update and leave it be.
morecowbell509
