The Adventures of Sylvester, the 2018 Suburban 3500 HD
Geotrash
Geotrash
Dave
Richmond, VA
I wonder if there's a way to monitor both fuel tank levels via PIDs with a scanner. Maybe graph them over time to see if there are glitches or other weirdness (technically speaking...)
So, I finally had a moment to consult Alldata, and here are a few clues. I don't yet have a scanner that can read these (haven't tried them all yet though), so I don't know if I can monitor the PIDs. But I suspect based on the information here, that the higher fuel consumption while towing caused too great of a discrepancy between the front and rear tank fuel level senders, such that the computer switched the fuel gauge off rather than risk displaying what it calculated would be inaccurate readings. I didn't check for stored codes so this is only a guess at this point. But per below, setting the fuel gauge to zero and illuminating the low fuel light is the expected behavior when a fault is detected, so the only thing that doesn't fit is that my low fuel light never illuminated.
koldrag
