The DOD tick finally got to me
j91z28d1
Glad I'm not turbocharging or adding a blower to this engine. But now I'm curious to see how off this thing, when I get home I will take a looksie.
they compensate for all of that during the initial Machining, so it really isn't anything we need to worry about. just a good reason if you're trying to turbo one, you either go the low buck. junk yard 4.8/5.3, don't look to close at it. and run it till it pops, or go aftermarket block. these in between builds can cost a lot of money and only be a a good as your machine shop.
Fernando Escobar
Los Angeles, CA
I lost faith in the machine shop near me when I took my heads in to remove my broken manifold bolts on a previous build. They claimed they could not use a welder to get them out because they were going to do more damage to the heads and that it was not possible. I know Steel and Aluminum don't bond to each other, but I did not want to sit there and argue. So in my effort to use a drill I broke the bits in side and ebay'ed some used 862 heads.
If they were decent I would have considered taking my heads to get ported but the cost may not be worth it if I don't plan to make a turbo build or something that's not the soccer mom hauler
Geotrash
Dave
Richmond, VA
Hello my fellow contributors on this DOD journey, so the Engine is out and dissembled. one of the AFM Lifters has a shiny spot on the inner corner (I'll show pictures later) the cam is not chewed up at all (I was expecting some carnage but it has some uneven wear patterns kind of odd. My camshaft Bearings are a bit discolored, I showed pics to my cousin (works for Toyota) and he says his recommendation is changing out the cam bearings, I was hoping not to touch the bottom end but I guess I have no choice so this DOD is sending me down a rabbit whole to taking every bolt right out.
Will the main caps be reusable if not damaged or is it better to just get all new bearings since everything will have to come off?
I will post pics shortly
Lordy Lord!!!
That cam has significant damage - enough to make a racket because it's on the ramp:
Fernando Escobar
Los Angeles, CA
Hey guys so as i was prepping to rebuild today. I took off the rear coversince all new seals were going to be used and low and behold this gem. The rear bearings has a bunch of little scratches. I ran my fingers and my nails woukd catch. Guess I will have to remove those bearing bushings after all
Geotrash
Dave
Richmond, VA
Well, shit. Probably best to take it to a machine shop and have the whole thing gone through. Then you'll be as good as new. To answer your previous question, the main bearings and caps can be reused as long as they're not damaged, but since you're likely going to be visiting a machine shop anyway, might as well bring the crank and have them set everything up for you. Be sure to also have them check those lifter bores.
Fernando Escobar
Los Angeles, CA
thanks already bought all the bearings after seeing this. I have done this job before so I have all the tools going to send the block to get it cleaned and honed tomorrow.
Fernando Escobar
Los Angeles, CA
Some more carnage from the main bearings. I guess wolverine was working on the line the day this engine was being built. All was going well but ordered the wrong piston rings so now got to keep waiting for now
Stevemo70
