The DOD tick finally got to me
BG1988
At first i thought it was an exhaust tick. Then realized it was probably the lifters. After our annual roadtrip to Mexico (Guadalajara) its gotten worse. And one day i did the remote start and it almost sounded like it was grinding. So its time to get ready for the rebuild. Im on the fence about still about a regular camshaft vs a a stage 1-2. Nothing wrong with a little more umph!
But most kits a see on line have vvt deleted. Good thing i know what I am doing... Except for the tune, i need to outsorce that
pulleys can make some weird grinding noses too.. replace them as well
BG1988
So after 180,000 of religiously changing my oil at the 50% life marker the lifters are looking like they are going bad and i am sure the camshaft is getting scored.
SO Its time to start looking for a cam and rockers that will be necessary for the DOD delete.
I don't know if I want to keep the truck as stock as it is or go with a mild stage 2 that does not need any major reprogramming and tuning.
So can any of you point me in some directions or threads to see if I can figure out a good build. like for example can I use a corvette/camaro cam with LS7 lifters and springs?
as I look at aftermarket brands, the more I research, the more overwhelmed I get with options.
Any help will be greatly appreciated, thanks.
every how many miles? 5,000 7,000? 10,000
Writefast
What made you think exhaust? My headers have a couple of rusted through bolts. She ticks a bit.
Fernando Escobar
Los Angeles, CA
I had replaced the bolts with studs and the bolt nearest cylinder 7 was broken flush the tick started getting louder at that time which coincided with my oil pan replacement and oil pick up tube o ring
Writefast
I had replaced the bolts with studs and the bolt nearest cylinder 7 was broken flush the tick started getting louder at that time hich coincided with my oil pan replacement and oil pick up tube o ring
Roger that.
blackelky
Texas speed dod delete kit
ls7 lifters and springs
And their stage 2 truck cam
You’ll be happy with it and it won’t be too too much probably around 1000$ maybe 1500$ if you get arp hardware all new gaskets and pushrods etc
How much you chargin for this lol ?
