The EBCM Nightmare, & how to get the module programmed.
kylebnoris
Alright gentlemen, this is my progress on my EBCM debacle and I'm grasping at straws now to find a solution, so hopefully someone can assist.
I have a 2005 Tahoe Z71 4x4 with the stablitrack / JL4 EBCM module.
We replaced the module due to no communication with the scan tool.
We had success with a JL4 module from an 05 Escalade, and have a line of communication with the scantool to perform bidirectional diagnostic and testing.
However, we have a intermittent ABS and Parking Brake Light on the dash, as well as a constant Traction control light.
From what I understand the module needs to be flashed / programmed per the VIN of the truck. The serial # and part # on the Escalade was exactly the same as the one that came off etc.
So here's my nightmare. Locally only two shops can program the module. One cost $400 and one cost $200. Both have informed us that if the flash fails, that it's a non-refundable deposit. That it doesn't matter if it's a Used module, remanufactured, or a brand new one from GM, that sometimes it just fails to take the flash and that we'd be out of the money and forced to find another and try again. Dealerships are all telling us it's too old to work on, and apparently this programming has to be done VIA OBD and cannot be done on a bench so it has to be physically installed and functional on the vehicle.
So my question is, should we take the risk, or should I try to purchase SPS2 / Acdeleo TDS / RAP2 ($3,000) Jesus) and attempt the programing myself? Is that even possible or will I need some sort of verified dealership key for it to even work? Or are we royally screwed here and left to this weird racket of a module programming network.
Thanks for all the help. I can't wait to post the final build sheet for this truck after it's done. Close to $10,000 in repairs, all for my buddies Later fathers truck to now serve him hopefully another 185,000 miles.
Thanks, this forum is awesome!
K
kylebnoris
Currently showing the following DTC's for reference. I'm researching via Alldata now.
DTC C0196 Yaw Rate Circuit
DTC C0283 Mode Switch Circuit Malfunction
DTC C0455 Front Steering Position Sensor Circuit
or
It doesn't specify which one of the C0455
These codes were not present before, and I'm assuming there are in relation too the EBCM not being correctly programmed for this VIN.
I have also attempted the Alldata procedure for recalibration of the Yaw sensor with no luck, so the idea I'm having is programming the module first, then troubleshoot anything afterwards.
or
well..... as far the ebcm if it was the exact same part it does not need programming
a intermittent issue is usually just that, either the ebcm is like most of them and needs soldering inside or you have something else triggering the code.
your current codes appear to be from the steering wheel angle sensor, not sure if "yaw" is integrated with the angle sensor or if it is a seperate sensor.
abs & brake light "can" be seperate issue's, best thing to do is scan it while the code is active, if the light is coming while driving and then going out when you cycle the key then it might be loose solder inside the ebcm. if this is the case and you scan it while the light is on it may show "lost communication yada yada" if so then that's your sign.
if you want to program the ebcm regardless it won't cost you $3k, it cost $40 per vin for 2 years programming, then you just need a decent windows 10 laptop and a gm compatible pass-thru device that could run you a couple hundred, maybe $300. then you can program any part of the vehicle as many times as you please for 2 years.
K
kylebnoris
When the lights come back on I'll attempt to have my roommate leave it running and grab codes.
I'm more than willing to pay for a GM pass through device, do you have a model number or a link to that, plus the location /website for the subscription? I'd much rather pay for that setup and find the EBCM still runs faults then go from there finding a replacement.
From what my research online has led me to believe, the part number for the module remains the same but is flashed differently per vin due to different vehicles packages etc. I understood that because of this the module we picked up is capable of being reflashed to this vehicle. However I could be wrong. If you have an explanation that would be awesome!
I reach out and get a GM part number for the module that is according to the parts department, specific for the vin. That # is 19368154 so I guess I could always try to locate it online, however I was again understanding that it still will require programing via OBD while it's installed on the vehicle regardless.
From what my research online has led me to believe, the serial number for the module remains the same but is flashed differently per vin due to different vehicles packages etc. I understood that because of this the module we picked up is capable of being reflashed to this vehicle. However I could be wrong. If you have an explanation that would be awesome!
I reach out and get a GM part number for the module that is according to the parts department, specific for the vin. That # is 19368154 so I guess I could always try to locate online that way.
as far as I know and have done myself, as long as the part number matches what came off of the truck it does not need programming.
also I believe you HAVE to use the same part number period new or used or it won't work, at least that's what I was told years ago when I replaced mine for like $50 versus $650+ for new one, it worked fine.
as for a pass thru device I use a clone MDI2 but there are a few other devices out there needs to be a J2534 device and compatible with GM
and the programming has gone up $5 20 it's $45 for 24 months, this is for programming only, it's not for diagnostics even though it installs a crapload of software, prog only.
also it is important to NOTE when installing the software you must run everything as administrator including the browser otherwise it won't install correctly and you will have a hell of a time getting it to work, has to be ran "as Administrator" every step of the way.
K
kylebnoris
Understood,
Found one single listing on eBay with a new Module for $450
Seems like that specific part # is very slim pickins. EBCM on Ebay
However I cannot verify other than the listing, and I no longer have the original module either, I do however remember making sure the part numbers matched when I swapped them.
For example, two listings show that same 19368154 in their descriptions but the visible label has two different parts or serial numbers, one of which match and one that does not. Maybe one is an applicable part number and maybe the other is a date of manufacturing or something and that's why their different idk.
Everywhere advertises these modules as "Escalade / Yukon / Tahoe EBCM" so I guess now I'm starting to think the module in the truck is the correct one, but I got a faulty one. It was only $40 from the local wrecker yard so I can't complain too much.
When I get the ABS and Brake lights in the cluster I don't loose communication with the module, I do know that. I'll look through my photos on my phone I may have gotten the codes pictured, but since the original module had zero communication, and this one communicates fine, I guess it could be damaged on the motherboard in a different way that doesn't make it completely INOP,
I was just assuming it was because it needed to be flashed for the specific vin.
I'm unsure, but I'll take your word for it. The listing if it's still available is a New unit, so if God willing it's still available, I'm gonna have my roommate buy it Thursday when he gets paid and swap it in. Hopefully it functions fine so we can finally cross this off the list.
The main reason it's important less for ABS tbh, but it doesn't look into 4lo only 4high with the abs lights on, but wild enough. The cruise control is disabled when the lights are illuminated, and even crazier then is that the wipers on the windshield are INOP as well, because I'm assuming they share some circuit on the turn signal stock.
So not only does the truck loose ABS but I also loses Windshield wiper function too, which is basically a disaster waiting to happen in the south with all this rain.
Understood,
For example, two listings show that same 19368154 in their descriptions but the visible label has two different parts or serial numbers, one of which match and one that does not. Maybe one is an applicable part number and maybe the other is a date of manufacturing or something and that's why their different idk. View attachment 435143View attachment 435144
wiper inop is likely the multifunction switch error, that's the blinker/wiper/high beam switch
or maybe even a short somewhere is causing multiple issues, I don't know how the switch would be tied into anything else
cruise wont work with errors set, neither will autostart.
I don't know I f I would drop the money on a module until you see what those codes are, anything from a abs sensor, brake fluid sensor, parking brake switch, master cyclinder, etc can set those off, although not usually together at the same time, but if you hit a bump in the road loose solder can make it throw a code, then when you cycle the key it clears until you hit the next bump in the road.
K
kylebnoris
Hmm, I'm gonna search Alldata and try to find out if they are infact separate. I was thinking the might share a signal together via like a CANBUS to the same module because I only every have INOP wipers when I have INOP cruise and those illuminated lights. Cannot repeat the issue otherwise.
I'm no Spark chaser so I'm still learning how to diagnose electrical signals and levels etc.
Very true, I did assume it was the module since it was immediately remedied upon swapping the new one in. But it could have been a INOP module + something else.
I did have a dying fuel pump & a sputtering injector and had to continue diagnostic after replacing the fuel pump so it's entirely possible.
SuitedSevens
