Think my engine just failed
Administrator
Bad gas would still be an expensive repair.
Possible but bad gas could also just mean replace fouled spark plugs and be done :shrug:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Wow that's tough I'm dealing with an engine noise on my 2010 5.3 w only 36 k just got new lifters installed under warranty and the sounds still there. I mentioned the oil pressure only being 20psi at idle and 45 at WOT and they said its Normal but I don't think so.... Just curious what your definition of low oil pressure is??
you are well above the minimum of pressure at those engine speeds.
---------- Post added at 04:58 PM ---------- Previous post was at 04:56 PM ----------
wow..rod knock would involve a whole rebuild no?
not really if the rod journal is undamaged you could like likey change the bearing with some fanangling from the oil pan area.
---------- Post added at 05:00 PM ---------- Previous post was at 04:58 PM ----------
and dom, for **** and wiggles have them change the oil and filter again when they are done.
D
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Ok. Hopefully there is an O'Reilly's out here. I use a Wix filter for a 2010 Ford Taurus. I know. Seems weird, but that's the deep version of the Tahoe filter. Difference is less than 1 inch and makes the bottom of the filter almost flush with the bottom of the oil pan.
D
domin8
Just Plinking
Breaking news: Rods bearing failed. Stealership is telling me $4600 for used engine. $5700 to replace broken and damaged parts. $6400 for new engine. Since my finances were tapped because of this trip for a funeral, goodbye Tahoe. Hello Impala.
soulsea
Bar
So what, the dealer is trading the broken hoe for an impala? :(
NathanJax
Vacation Nathan
Administrator
Jax, Fl
WOW!
x2
so what are you doing? trading in the tahoe with a blown motor for the impala?
I think I'd get a malibu before an impala.
Chrisisgay
