Tips/Advice from anyone that has replaced control arms?
2010gmcyukon
Midwest
It looks like its time for ball joint replacements on my 2010.
The quote from my usual shop for replacing the 2 lower ball joints and the 2 upper control arms (w/new ball joints) is about $1860 + alignment. Its $783 parts and $1076 labor.
My understanding is that if I'm going to replace ball joints myself its more efficient to just replace the control arms (upper and lower). I priced 4 new Moog CK control arms w/ball joints at $434.
So already there, they have marked up the parts quite a bit. I watched a video on replacing the upper control arms and this is a bit more involved than I thought. I did replace the front struts myself last year and I do a lot of the other basic maintenance stuff.
I'm really on the fence about doing these in my driveway. Does anyone have any advice on doing these myself? Is it worth the $1k in labor to not mess with them?
Geotrash
Dave
Richmond, VA
I did mine on my '07 a few years ago and it was a straightforward job. It took me a whole Saturday to do both sides, and I recall a few things from it that might be helpful:
The tools I had for working on regular-sized cars, such as my HF ball joint separator, were too small to do the job on the gargantuan size parts on the Yukon. So I ended up using a good old-fashioned pickle fork to separate them, which worked fine because it was an Arizona truck, but could be a challenge if they're heavily corroded.
Removing and tightening the upper control arm bolts to the frame required a very long 1/2' drive breaker bar. And even then at 6' and 230 lbs, it was all I could do to get those bolts off. And the tightening torque was greater than my 1/2" torque wrench was calibrated for, so I felt sure I was gonna break either my torque wrench, the bolt, or the frame mount, getting it tight, but it worked out fine. I just maxed out my torque wrench and switched to the breaker bar for one last oomph of torque on each.
IIRC, the lower ball joints need to be installed and torqued with the weight of the vehicle on them. Check the manual to be sure. You will need a jack on the bottom of the brake rotor to do this. It's important because if you don't, the dust boot will fail early.
While I was in there, I checked my wheel bearings and they were fine, but installed new brake pads and rotors, new sway bar links, and outer tire rod ends.
Take it in for an alignment when you're done.
2010gmcyukon
2010gmcyukon
Midwest
Thanks for the input. I'll read up more on the lower ball joints...my hope was that they were pre-installed in the arms so I didn't have to mess with them.
Tonyv__
Bucks county PA
I got roughly the same quote for my 2015. About $1700 so I see that’s the going rate and I wasn’t exactly getting beat over the head…. I’ll still be doing them in my driveway. My Yukon isn’t my only car so If i have to walk away and get to it the following day or so it will be fine
Tonyv__
Bucks county PA
What’s your torque wrench maxed out at? I just bought one today 50-250lb. Hopefully that will do the job. I plan to do mine in the spring
Check the prices for the ACDelco Professional upper and lower control arms, they are the same item and last time I checked, they were much less than Moog.
I did a write up on this on my build page called "useless information" earlier this year. Proper tools are key to make the job as smooth sailing as possible.
So, exactly what parts are being replaced for $783? Oh my word! Just looked up the ones I purchased in the spring and prices have skyrocketed! I was having a heart attack then over the prices, this is crazy now!
Bill 1960
Testing the Limits
It’s not a bad driveway job. I replaced all of mine and installed my lift at the same time.
$1k probably only buys you 6 hours of shop time plus an alignment at today’s rates, which is about right. I’d take longer than that doing it myself, but I’m slow and meticulous. It’s not really a bad job unless you have salt corrosion.
black2002tahoe
