I don'tDo you have a login to the site? I couldn’t see anything from my phone, but once I logged in on the desktop, they showed up. Let me know, I can email to you or something if that would help.
Sent an IMI don't![]()
I found a better build than yours tony, sorry, some one had to be the bearer of bad news.
Pretty sure your Denali has DL3 as standard. Have you checked your rpos? If not, make sure they work on the Hoe, then try swapping the driver side mirror along with the switch. It'll take you 10 mins. It SHOULD work. If not, just swap it back.I was considering swapping the DL3 mirrors from my Tahoe to my Denali but after seeing what a hassle it is to get everything working, I prolly won’t now.
Got some lope at idle....I found a better build than yours tony, sorry, some one had to be the bearer of bad news.
He's got some big DL3's too.Got some lope at idle....
I checked for the DL3 RPO but it doesn’t have it. Maybe because it’s an 02? But I’ll try that swap today. Good idea. If it works , then Ill just have to see about swapping the caps.Pretty sure your Denali has DL3 as standard. Have you checked your rpos? If not, make sure they work on the Hoe, then try swapping the driver side mirror along with the switch. It'll take you 10 mins. It SHOULD work. If not, just swap it back.
