its says bank 2 is lean. really lean. like vac leak lean, but that would be both banks showing lean. so likely a wet o2.
a neg number is rich, pos numbers are lean. so you got a +18 long term and a -31 on the short term, thats the pcm trying to make it right, but it cant win this fight lol
Sorry for the misunderstanding @Scottydoggs. I was referring to your first sentence, bank 2 lean. The fuel trim is subtracting 31% fuel which would mean that bank 2 is rich like you said in second paragraph. That’s all I meant. I don’t claim to know everything, I’m only trying to help. I apologize for adding confusion to the situation.
Don't you worry @Snowbound , we know you were just trying to helpSorry for the misunderstanding @Scottydoggs. I was referring to your first sentence, bank 2 lean. The fuel trim is subtracting 31% fuel which would mean that bank 2 is rich like you said in second paragraph. That’s all I meant. I don’t claim to know everything, I’m only trying to help. I apologize for adding confusion to the situation.
Don't you worry @Snowbound , we know you were just trying to help. Wish you knowledgeable guys could give a class on this stuff, so us unknowledgeable guys could learn it! Good info
still dont change the fact that that o2 was reading lean......
not sure if you know the difference between a neg and pos numbers, you got your pcm jargon down good, but they are backwards when you read them, neg is rich, pos is lean. stft like you said is the correction of the ltft. so the stft -31 is adding the fuel back to change the the ltft +18 back closer to zero where in a perfect world is where it should read.
go pull a large vac line off any car, the ltft will go pos up to +16 or higher. thats a lean condition.
You are correct that negative is rich and positive is lean.
You are incorrect in saying that -31 is adding fuel. It is, as you said a rich reading, and the computer is taking fuel away to get back to stoich.
Not to be a smart-ass, but in summary...
Negative fuel trim = rich condition = taking fuel away.
Positive fuel trim = lean condition = adding fuel.
Your second statement is exactly right. A huge Vacuum leak means tons of extra air, a lean condition, and a positive fuel trim, because the computer is dumping a ton more fuel in to balance out the excess air to try and make stoich.
