Tonyrodz's Tahoe Build Thread
Think I'm gonna go get some MAP gas and that 22mm wrench from HF. Only thing tho--since that nut started to round, the 22 might not be snug enough and slip. Any suggestions about that?
Unplug it if you don’t wanna cut the wire off, and put the box end of the wrench on it. That way you just put the wire through the wrench. Or use a pipe wrench, might get better leverage that way anyway.
NoReverseYukon
NE Wisconsin
Not knowing whether you are tackling up upstream or downstream, and not wanting to view anymore thong eye-candy (!?), you have removed the exhaust to get the best angle at removing that little SOB, haven't you ?
Administrator
Six point deep impact socket and cut the wire off.
He's got a whole set of O2 sensor sockets should shouldn't need to go that around. Just needs to man up and show that sensor who wears the pants in this relationship.
@Tonyrodz , remember righty-tighty, lefty-loosy
Sam Harris
Texas
Not sure but this could be the one in the same snowblower guy or maybe a Sam look alike. But I don’t think he wouldn’t mess around with a single stage blower. He is truly a wordsmith.
Lol. Awesome. Great advice for a hookajooked bolt! [emoji23][emoji1787]
Grounds for what...? That’s a hellova ground wire for an O2 sensor... as I said above, MAPP is no longer stocked in your regular HW stores. It sucks.
Yeah, wasn’t that a week ago? Seems if somebody wanted this thing fixed, that would have been ordered and delivered by now. This repair is taking longer that it took to build the truck in the first place! :rage:
Jnmbth
