Not sure. I haven't gone out with it since I went out with the Tech 2. I remote start it every other day, just so the battery won't die. It runs for 10 mins then shuts off.Truck still running good?
It needs to be driven. Get with it! Why aren’t you driving it?Not sure. I haven't gone out with it since I went out with the Tech 2. I remote start it every other day, just so the battery won't die. It runs for 10 mins then shuts off.
I know it's bad to let any vehicle sit, that's why I got rid of the GN. I haven't worked, and we don't really go out--just food shopping or dr visits--and we were always using my work van since the tahoe was messed up all the time.It needs to be driven. Get with it! Why aren’t you driving it?
Yours just had an O2 sensor replaced, it needs to be driven some so the ecm relearns fuel trims and the sensor gets broken in, plus your engine hadn’t been driven much since it’s been put together. You should drive it as much as possible for awhile.I know it's bad to let any vehicle sit, that's why I got rid of the GN. I haven't worked, and we don't really go out--just food shopping or dr visits--and we were always using my work van since the tahoe was messed up all the time.
Now that it's running better I will. Now....just need errands to do.Yours just had an O2 sensor replaced, it needs to be driven some so the ecm relearns fuel trims and the sensor gets broken in, plus your engine hadn’t been driven much since it’s been put together. You should drive it as much as possible for awhile.
Go get me a pizza dammit and deliver that sucker. That should do it.Now that it's running better I will. Now....just need errands to do.
On my way you grumpy old manGo get me a pizza dammit and deliver that sucker. That should do it.
It'll get better! Can't get worse
