Tonyrodz's Tahoe Build Thread
I just changed the radiator. It cracked right under the upper hose neck. Those damn Gm hose clamps took forever to get off. It happened a little while after picking it up at the shop.
I just changed the radiator. It cracked right under the upper hose neck. Those damn Gm hose clamps took forever to get off. It happened a little while after picking it up at the shop. View attachment 82624 View attachment 82625 View attachment 82626
You need a pair of these hose clamp pliers. They ratchet closed so you just crank them down and the clamp stays open, and then you can relax and move the clamp where you need to. Easy peasy. Ebay $12 for a set.
95escahoe
No shit! Guess what now! View attachment 82630Has first, goes to 2nd and that's it. Whines like crazy. Think it could be a solenoid? Reverse works, but the fluid is a little burned, it's a little brown, doesn't really smell bad tho. Solenoid or trans? Anybody?
Damn that sucks, when was the trans last serviced?
I don't know shit about trannies but Im hoping it doesn't need a rebuild. Not good though. Sorry Tony.
Thx Red. I think it's gonna need a rebuild. I knew it was just a matter of time before it happened. Of course it has to happen on a holiday weekend.
Racerzl1
