Stonefort
- Joined
- Sep 28, 2020
- Posts
- 124
- Reaction score
- 243
Did you get the pcm flashed for the fans?
I did it myself with HP Tuners. I found a stock 2005 tune and used the "compare tunes" feature to see all the differences and then made them. I was intimidated by putting the two pins into the ecu harness but it wasn't that bad. If you have HP Tuners I can do the tune changes for you.
With a stock harness blue wire goes to the green connector on pin 33, blue wire goes to green connector, pin 42. I used a needle to punch through the hole insert and I had to take off the transparent colored covers.
