Trans Pan removal
B-train
Be aware that when you slide the pan out, that you don't damage a shift solenoid. A friend owns a trans shop and warned me of that years ago.
Multnomah Falls
I saw a video at you tube about using a 2x4 and a ratchet strap to pull/flex the exhaust down just enough for clearance. You have to remember that getting the pan down is only half the battle. You have to get the pan and gasket back up in that hole.
I thought @iamdub had a trick for this very situation for "persuading" the Y-pipe to cooperate.
This Y-pipe?
Persuaded to cooperate:
:yaoface2:
I recall it being tight, but not very difficult. But, mine is a 4L60E so the space constraints are probably different than the OP's 6L80E. I also have a lift so I can easily use prybars and/or lengths of 2x4, which is what I might have done. I just didn't put much thought into it and didn't bother to memorize whatever it was I did. Actually, I probably did my trans stuff after I cut the pipe out.
Multnomah Falls
That linkage bracket is a PITA but once you get the torx broke loose, it goes pretty smooth. Chase those torx threads and holes and lube when reinstall.
B
blondie70
I got 'er done. I used the jack method to raise the rear of the trans, as was outlined here. Got it finished today. No leaks yet...ha ha. Thanks for all the good suggestions for this job. 2 or 3 or7 heads are sure better than one ! thank you
Caveman1975
I just did this job on my 2014. Had the same problem. I used a 3 or 4 ft piece of 2x4 steel that I had laying around.
Wedge it above the exhaust. Push it up against the chassis rail. Use a floor Jack on the end. It becomes a lever, and the chassis rail is the fulcrum.
Pushes the exhaust down just enough to slide the pan off, without taking the exhaust apart.
TXbarney
Seem logical that raising the transmission is simpler and less involved than taking frozen bolts loose on the exhaust.
However if you are more skilled with a sawsall all than wrenches I guess you would start cutting.
* consider this...... note that the cross over goes under the trans pan for about 10-12 inches. how much heat
do you think that radiates into the transmission? While you are under the vehicle, make a heat shield to reduce the
heat from the exhaust raising the transmission fluid temp. .... really cheap insurance for the transmission.
Scpori
