Transfer case problems :(
saif najd
saif najd
This I the pictures for all the leaks I think
saif najd
saif najd
are these constant leaks, staining the components, staining the ground lightly, or staining the ground lightly.
Hi sir,
No I couldn't find any stains under it even I left it in the parking lot for 3 days nothing no spots
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Then in that case leave them be as just leakge stains from the mileage on it. Should not have to worry about them just check the fluid levels on all of the drivetrain. But if you need, get that shaft play felt with.
saif najd
saif najd
Thank you for the advice, I am facing two new problems:
1- i couldn't add or check the level of fluid because
2- I couldn't unblug the screw of the transfer case because it is welded to the case!!
Tomorrow it will go to the shop to drain my pocket :banghead:
SunlitComet
OBS Jedi-Do Good
ouch it was the fill plug welded or the drain plug welded?
---------- Post added at 01:46 PM ---------- Previous post was at 01:46 PM ----------
pic if possible please before you go to shop.
saif najd
saif najd
Filling
Sorry I cannot take tge pictures niw it is already at the shop :(
I will try to visit them today
saif najd
saif najd
This is the info I found on the transfer case
By the way we found broken plastic yellow circle and they told me if the (fork) is broken! Then it won't be fixed because our market out of stock (all internal parts for the transfer case not available!!)
So I think I have to look for a site would sell this parts
saif najd
saif najd
In the second picture you can see the filling plug condition
audley71
