I did a paper-towel test today and it looks like the transmission fluid has most likely been changed as it looks nearly pink with just a slight brown discoloration. No way at 200k it would not be dark I would think. On the attached pic I poured some DexroVl on the left side and pulled the trans dipstick several times to coat the right hand side. My plan is to pick up about 6 quarts of DexronVl and drain whatever comes out of the trans cover drain plug and refill back with new. Next summer when the weather warms a bit I will drop the pan/change the filter and check for any sludge. The 2ML70 is a beast of a trans. It apparently has some components that a normal trans does not have.
![Trans fluid pic.jpg Trans fluid pic.jpg](https://www.tahoeyukonforum.com/data/attachments/208/208357-75e358b41006a86870014d3c9b7fc521.jpg)
