transmisson problems
J
jmc86
Well took it to a trans shop dropin off.the kon tomorrow should be done by Sat for 1100
J
jmc86
3 differant shops said I needed a rebuild and it would cost x amount of dollars(
3shops 3prices)1100 with a 1year warranty was the.best option presented and that's the shop doing all the work. I had one shop tell 1500 if I pulled and put.back in. (I lack the.know how to do it) and offered no.warranty the 3rd shop offered 1100 6month warrenty they do all.the work so 1100 for a 1 year is the best choice unless all.these prices are way to.hk ugh and.I'm.getting.bent over royally idfk.at this point lol
SunlitComet
OBS Jedi-Do Good
unknown at this time.
and how did they diagnose it cause mine had to be torn down to physically show me what was wrong and my overhaul cost me $2500 with all new solenoids and a reman converter as well. my labor section of bill was $1100 of that total and all i did was burn out a clutch pack. no chance you have a broken circuit somewhere?
retorq
Kingman AZ
The beast is not a better choice then the newer Sonnax smart shell. Have you looked at the design of it?? People building new trannys aren't going with the beast now a days, they are using the Sonnax one now unless someone with old info that doesn't know the new stuff is suggesting it. And really, who's building 4L6x for drag racing hahahaha
NYFreakinRican7
Hampstead, North Carolina
Mine just started doing the same thing. I had a history code for the 1-2 solenoid about a month ago before I did my tune-up and cleared the codes. Only code I had now was for an O2 sensor. I'm wondering if the solenoid has anything to do with the 3-4 shift also?
#1taho
5150TAHO
niagara falls ont
slipping ???
over the last few days it feels like first gear slipps once and a while!! never had a problem untill now. fueses are good no codes and fluid is clean. It dont do it all the time, when it feels like it. dont matter it its warm or cold and dont matter if it long run or short. I took truck on a two hr run yesterday and it didnt slip once on the way out. On the way back it slipped once just after i left when it was cold. any thoughts ?
elianymanol
