Tried to upgrade rotors; caliper bracket doesn't fit
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
So I waited all day for it to cool down and then tried to swap my warped rotors on my K2xx with some Raybestos Element3 rotors that I had in the shelf for my GMT800.
They fit the K2xx, but the stock caliper bracket is too small. Can I get a larger caliper bracket or do I have to get new calipers if I want to use these rotors? (I had a pair of Raybestos 4 piston calipers to go with the rotors, but they didn't come with brackets and I can only find one of them at the moment o_O)
Pilot
Pilot
Looks like they MIGHT fit with some washer spacers, just makes me uncomfortable how tight it is.. although I am able to rotate the rotor with my hand, it feels like the rotor is coming into contact with the caliper bracket.
Also, look at the piston seal on the lower piston in this pic. Looks effed. Should I replace this caliper before driving with it?
Marky Dissod
With my '02 Tahoe I had to upgrade the pads rotors calipers AND caliper brackets
by using the '10 pads rotors calipers AND caliper brackets.
Guess what I'm asking is, are you using the newer caliper brackets?
If not, try using the newer ones.
Pilot
Pilot
I don’t have new brackets. And after seeing this piston seal, I don’t want to put this wheel back on until I’ve replaced this caliper.
This is my only vehicle at my current location so I’m just going to go with local OEM parts for now so I can get this rig back on the road. Anything else would need to be ordered.
I’ll do a proper brake upgrade when I have time to order all of the parts.
Tator Tahoe
