Do you think I should've stuck with stock arms?
Are the arms any different than stock (longer, different geometry, etc.)?
Would I benefit more from the alignment bushings if I went lower on the adjustable struts?
edit: Are the alignment bushings meant more for coils and adjustable struts?
If the bushings did, in fact, over-compensate, then yes, going lower would help. But I wouldn't go lower just for that unless you're wanting it to be lower. I would adjust the eccentrics to see if they'll pull the tops back in. Your alignment is already whack, so you can only help it get better. You just need it good enough to get it to an alignment shop. Hopefully you have a good one nearby.
I just got the drivers side wrapped up on the ground on its own weight and its doing the same thing.
Would removing a couple of spacers from the struts help?
Removing spacers would lower it, so, yes.
Did you leave the control arms loose until you set the vehicle's weight on them?
