Under hood storage box
2591tdj
Miss
My former 1997 Tahoe came with a black plastic storage box and lid under the hood at the left front corner where a 2nd battery would have gone. It was a great place to store jumper cables and tow strap.
My 2019 has a similar place for a 2nd battery but does not have the storage box. Anyone know where to find a similar box that would fit in the space (max 11” x 8” x 10” tall)? A 24 series battery box is too big. I’ve searched on-line and in local stores. No, I’ve not tried locating one from an earlier model Tahoe. There are no vehicle junk yards anywhere in this area.
TollKeeper
Brighton, CO
I think Summit sells a battery box you could put in that space. But you would also need the original battery bracket that would go there if you had 2 batteries.
St. Louis
There was a post about this a while back in the 2007-2014 section. I think someone found a certain sized ammo can would fit, and could be bolted down. I think for ease of opening the lid though, that corner support bracket had to either be removed or use a wingnut or something on one end so it could easily be loosened and swung out of the way
2591tdj
Miss
The standard bottom battery support plate is there. I can either bolt or strap a box on that plate. If needed I could easily put a battery there now and add a hold down clamp.
in fact I’m thinking about putting a 24 series boat battery there for transport to the lake this weekend. It would be safer than carrying it inside the Tahoe for the 2 hr drive. No risk of it falling over and leaking inside the vehicle.
Thanks guys. I hadn’t thought of checking Summit. I’ve measured some ammo boxes but so far there’s always been one dimension that wouldn’t fit.
clublub69
