volant intake help
95escahoe
good evening, I picked up a volant intake from someone off here, pretty much have it all on just can't figure out what hole the mounting bolt goes in, cause u have to remove the two factory ones to install it, and how much to u gotta put it in cause after a few turns its pain to get it to go in.....and this is for a 95 tbi tahoe
95escahoe
95escahoe
thanks again and yup those did the trick
95escahoe
95escahoe
Deff like it man, it seems to go a lil better when u step on it and I think it maybe made my exhaust a lil louder
dfrom216
95 tahoe help
i see your close by,i have a 95 2dr tahoe and im trying to make it breathe again lol,do you know of places to get doors,door panels,tailgate or even a nice/cheap body shop,i do check pull-a-part but always late
95escahoe
95escahoe
where in ct are you from? up at chuck and eddies in southington theres a mint 96 or so burb in the pick your self section it has barn doors but the other doors were in mint shape and had the panels and all that still, what kinda body work you need? I know of a good shop in naugy
Stresst
So the Volant intakes are the way to go? I already have a K&N filter is the Volant intake worth the money? Does it improve power and mpg or just power? Not sure if 300 bucks is worth it?
99Yuk
Northern Ontario, Canada
Sorry to disagree with you Atomic, but....
No, it's not worth it. Volant and K&N full air intake kits vs the stock intake with a K&N filter is not worth the $300 extra.
I've done research on the differences HERE.
The full CAI kits replace the OEM GM tophat (flat 90degree elbow on top of the Throttle body) and gives you a 4% increase in air volume. Volant DOES suck in cooler air from the fender, but drops air volume because of that. That 4% increase in air volume is the only difference.
I've noticed by monitoring my intake air temps, outside ambient air temps and water temps/efan activity for about a year now, that with my K&N drop in filter and top of air box removed that HEAT SOAK is not an issue. When the truck is moving at any speed faster that 15mph the intake air temp is the same as the outside air temp.
BTW, I really like mine too...
EDIT: Honestly, If I knew this info before, I would have just bought a $60 Ebay Spectre or Airraid kit and be done with it.
Just my thoughts (as I put on my flame suit)...
dangerman4203
