Vortec 454/4L80e HD swapped 1999 Tahoe OBS
6.0 Carb Conversion or Stay EFI?
  • Carb Conversion
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
bigfootchiro
bigfootchiro
Largo, FL
i would go big....for when you supercharge this thing :anitoof:
Do the most common injectors - I am not really familiar with 0411 tuning but theres a good chance if you use a common ls1/ls6 style injector oem or even a generic 60lb/hr injector someone will have all the data the tune will need
Funny thing is, there aren’t any guys, except for a couple, that have 0411 tuning for the 454. I’ve been emailing Jim of PCM Power Tunes, and states he has an “aggressive” 0411 base tune for the 454. He can change the tune based on my mods, but then suggests having it dyno tuned after the swap. When do you know if you have too much injector? Just swap out different sets, push it on the dyno, and see which one starts stalling out?
I think that's where live data would come in handy. I'd think by looking at the numbers--for someone who knows what they're looking at--they'd be able to tell if you're way rich or not. Just a guess tho. I'd also guess that they'd be able to dial down the fuel just by tuning off the lap top. Again, just a guess.
randeez
south florida
if you have them tuning for you ask them what injectors are best, usually choose injectors according to how much power you want to make.
also if youre using hptuners in the tune repository under account there are a couple of 454 0411 tunes up you may be able to copy some info from
bigfootchiro
bigfootchiro
Largo, FL
I’ve got a bit of a hard start issue going on, and these motors are notorious for FPR and/or injector issues. Gotta do a leak down test and find out
bigfootchiro
bigfootchiro
Largo, FL
Alright guys, here’s a video of some lugging it’s doing. May be related to FPR or injectors. It lugs down under consistent throttle position. You can hear the engine lug and drop in RPMs, even though throttle doesn’t change. It’s very noticeable while driving, and you can feel slow you down. Possible FPR and/or injectors. Leak down test is positive, and smell of fuel under the hood. What are your thoughts y’all?
randeez
south florida
Yep. That’s your end goal right? Blow the motor so u can make a call to Texas speed?:D
me? ive already got enough injector to do 1k+ :anitoof:
but they kinda expensive, theyre tested/matched set and tune data they provide takes all the guess work out of getting them going. i went from flex fuel injectors to 1200cc and it started right back up and idled like stock since day one.
stock flex fuel injectors would be good for him, would flow enough for about 550hp, but they are about an inch shorter than the standard ls1 injectors would need to figure out what size hat adapters. and all the data for them can be found in stock tune files.
CoyotesRUS
