Want to take my 2010 Yukon XL Denali with 180,000 miles for a family trip from Michigan To Florida - Can you help me make this a success!
B
bobby2175
Yes. 5801095 is the part number I installed on my 2012 exactly 3 years ago:
Just trying to think through how to get to that top bolt and make sure I can break it loose after 13 years of dirt, salt etc up here in Michigan. Can you suggest the proper tools? That's the one part I'm worried about - I don't have a lift. Just a floor jack. Will I be able to get up there with enough leverage to get it out?
Torque specs on those bolts?
How would I go about getting XM radio to work with this head unit?
depends on the year. if yours has xm already and if it is a separate unit then it can be made to work thru the speedometer cluster, if it is built into the headunit then you need a
svx300 tuner kit which runs about $45 then it will interface directly to the aftermarket radio
B
bobby2175
The coils for the models with ALC are a little softer since they rely on the air sleeves on the shocks to supplement the load capacity. With the sleeves blown/inoperable, you're left with the springs alone that are a little too soft for the vehicle's carrying capacity. If the rear is too soft for your everyday driving and/or you tow or carry a loaded cargo hold often enough, you can slip some air bags in the rear coils and just add a few PSI for those times you're loaded. Basically just doing manually what the ALC system does automatically. Air Lift and Firestone have kits for these rigs. The Air Lift 1000 bag kit is around $130 and can be installed in a couple of hours. Best I can tell, the Firestone (Coil-Rite) kit is comparable, just has blue bags instead of red.
You can disable the ALC by disconnecting the negative battery cable, removing a couple of fuses then reconnecting the battery. If that is the source for your suspension warning messages, this will eliminate that. Personally, if the shocks are otherwise fine and you just need to fix the sagging, I'd spend the $130 bucks versus four times that for the factory style shocks with the air sleeves plus the $200 for the compressor that might be blown.
Find your kit here:
Air Lift
Firestone
Also, lemme know if you get serious about the Big 3 wiring upgrade. I've gotta rush off to work. But I have pics, etc. in my build thread I can use to give you some pointers. I don't know what electrical gremlins you're experiencing. But upgrading the major circuits would at least rule out the factory shortcomings so you'd know if the problem was elsewhere.
The airlift 1000 kit says "will not fit models with factory auto leveling option". Assuming I can't use that one. I'll look at the Firestone.
I'm absolutely serious about big 3 and upgrading my audio before I leave on the trip. I have a couple blown speakers including the center one in the dash (which is a bad place to have a blown speaker), tired of the head unit, and want to upgrade my audio. Would love to do this before the trip as we are all into music and the truck will be blasting something the entire drive. I don't know where to start on any of this.
My configuration is like this thread below where the mega fuse is integrated with the positive cable and not at the firewall.
@iamdub - can you give me a little guidance on the big 3? Please see in the link above that I have this configuration and don't fully know where all of these new wires will go. Still learning my way around the truck.
B
bobby2175
All the air springs say they’re not compatible with the Z55 equipped trucks. And I don’t know why that is but I’ve read it everywhere. It’s just a matter of measuring your rear coil springs and finding bags with matching dimensions. I’m guessing Firestone will say the same thing. I run airlift 1000 bags on my truck since I do so much towing and I figured it would be cheap insurance to help preserve the life of my Z55 shocks. It’s worked wonderfully. I agree with the comments that you could do the air springs option and manually fill them when you plan to carry lots of people and cargo weight on a trip to prevent sag. That’s a good solution I didn’t think of. Good “easy fix” in the interim while you decide on which way to go on shocks. And the plus side is that manually filling them is easy peasy…. I bought a really cheap small air compressor from a small California chain hardware store that I have a branch of in big bear. It’s just a little 12v cigarette lighter power compressor that you can use for tires. My airlift bags max out at 35PSI capacity. When unloaded I keep 10-15 PSI in the bags, a little more with detail gear loaded in, and 35PSI Max capacity whenever I have a boat hooked up. My air compressor is small enough to keep the cord and air line bundled up and stowed in the rear storage compartment where the bottle jack and tire iron and tools get stored. I pull it out and it takes all of 30 seconds plugged into the rear outlet by my tailgate to fill the bags all the way up.
@adventurenali92
@Geotrash
So, I'm going to purchase the rear shocks and compressor. I went to the grocery store the other day and loaded up just a few things - a couple of cases of water - and with just that little bit, the truck sags way more than it should.
I've found a couple of videos that walk me through the installation of the shocks/compressor...looks mostly straightforward. Question - are the upper bolts as difficult as they look to remove? Any suggestions there? Seems like I'll need a socket extension to reach it, but is that it?
Also, the air springs like you mentioned above - should I install those as well as the new shocks and compressor to take load off the overall system? I think I'm starting to tinker and doing some of this for just fun now. It's definitely been a lot more enjoyable than I expected starting to work on my cars.
Geotrash
Dave
Richmond, VA
@adventurenali92
@Geotrash
They were easier to access than I expected. Yes, you'll definitely want to have some extensions on hand. Mainly just have to watch to make sure you don't inadvertently separate the wiring connector that's up there, but if you do just be sure to reconnect it.
If you replace the rear shocks with the OEM Z55 parts and put in a new compressor, you won't need (or want) any additional air bags. I think folks were mentioning that in case you didn't have time or want to stand the expense of replacing the factory parts. In that case, the additional air bags would be a viable solution.
Note that the Dorman compressor comes with new air lines. While it's likely your factory lines will be fine, it's something to think about.
B
bobby2175
Thanks so much! Do you recall the torque specs on those bolts?
85ft lbs
rears should be done with axle level with how it normally sits on the ground, so jack up the frame and support it, remove wheels and then jack support the axle so you can move it up/down as needed to fit the shocks on
you will probably need to use 2 sockets (one on each side) if i remember correctly. you can do it without having to pull the wheel shroud off, just reach up behind it
Geotrash
Dave
Richmond, VA
85ft lbs
Very important advice. You don't want the rubber boots on those shocks to roll over themselves by setting the back end down before the bags get some air in them.
B
bobby2175
85ft lbs
Thanks so much for this!
So, for someone who knows nothing, I just want to make sure I understand.
1. Jack up the frame and support it with jack stands.
2. Pull the jack and now raise up the axle to be able to have control over the installation with it in its normal position.
3. Install the shocks
4. Put the tire back on
5. Remove the jack on that side
6. Repeat for the other side
Do I follow this same process for the removal as well?
I will look to see if I can find some good videos on jacking the vehicle up at the rear. This is definitely one of my blind spots.
Polomatt
