Oops I don’t remember…and I noticed that thread I linked said nothing about it.Hmmm. Pretty sure my AC Delco water pump had right-hand threads for the fan clutch. Right-tighty, lefty-loosey. Or am I wrong?
I replaced mine with an ACDelco OEM. It was from rock auto.I don’t know what radiator to get I don’t want a Chinese pile of junk one but i don’t wanna swap in a used one I finally budgeted out the money for a new radiator just need to find which one to get Any idea which one to get?
Edit: I got confused there because I saw your post about rh threads and then the OP said “ correct righty loosey “ which is wrong right? Hahahaha shit.Oops I don’t remember…and I noticed that thread I linked said nothing about it.
I will think about it because it’s a somewhat major decision however any radiator that doesn’t leak and fits is definitely better than mine rnI replaced mine with an ACDelco OEM. It was from rock auto.
I thought I was crazy when the dang thing wouldn’t come off when removing it righty loosey but I figured out the dang thing is tight which is good for it not falling off but bad when trying to remove itEdit: I got confused there because I saw your post about rh threads and then the OP said “ correct righty loosey “ which is wrong right? Hahahaha shit.
That part number leads me to a water pumpSame. #252-845 (without thermostat housing)
I think you’re turning it in the wrong direction if you’re acting like it’s reverse threads because like @Fless said it’s normal threads, at least I’m pretty sure it is. So lefty loosey righty tightly.I thought I was crazy when the dang thing wouldn’t come off when removing it righty loosey but I figured out the dang thing is tight which is good for it not falling off but bad when trying to remove it
