Bigkevschopshop
Did you lube the oring before installing? I have seen them cut or minor split when installed dry.
No, it is metal and rubber. What would you use to lubricate it?Did you lube the oring before installing? I have seen them cut or minor split when installed dry.
Pag oil if you have any extra.No, it is metal and rubber. What would you use to lubricate it?
Reputations are a hard thing to live down.I use KY gel to lube o-rings. It's water based and doesn't break down the o-ring. People think I'm weird having a tube of it on my workbench though
