I didn't use any oil, only evacuated the refrigerant, not the oil. I thought that most of the oil resides in the compressor, no?Also, what type of pag oil did you use?
I did take a photo of the leak to show the dealer but in the end decided to make the repair ourselves. I promise to photograph the repair next time! Well, I'll have my kids take photos and send them to me for posting!First, I would highly recommend staying out of the hospital at all costs. Hope all is well.
I always put a little pag oil on o-rings and seals. Just helps them seat in place. Maybe it’s not recommended but I’ve always done it without issue.
How long are we talking before leak developed? A week, month, year? Could the condenser be leaking above the fitting and running down to that connection? Maybe on the backside where you can’t see it? I’ve seen people over tighten the bolt and fracture the tube where it meets the aluminum block. Some of them rubber encapsulated metal washer seals can be slightly larger than OEM or even egg shaped straight out of package. Could you have gotten a bad seal? Hate to see you replace line and condenser only because of a bad seal but I hear what your saying about doing it once.
Usually a bad line leaks at the crimped fitting not the connector unless it got smacked or cut.
And yes, the system should hold vacuum indefinitely unless there is a leak. I don’t know anyone who holds vacuum for more than an hour while checking for leaks. If it doesn’t lose vacuum within the first 30 minutes chances are it won’t.
And what’s up with the lack of pictures? Don’t you know we are all picture ****** and live by the motto, pics or it didn’t happen. I would like to see the surfaces if it’s apart.
Oil will gather in bottom of compressor, the evaporator and the condenser. That is why I like to flush and then start with a full charge of oil in the system. Minus what may be shipped in the compressor if you are replacing the compressor.I didn't use any oil, only evacuated the refrigerant, not the oil. I thought that most of the oil resides in the compressor, no?
Well, we're only going to replace the accumulator and condenser and the line between the two. I reckon we can drain the oil from the condenser, measure it, and put some fresh oil in the new one?Oil will gather in bottom of compressor, the evaporator and the condenser. That is why I like to flush and then start with a full charge of oil in the system. Minus what may be shipped in the compressor if you are replacing the compressor.
A flush would entail using a recovery machine and disconnecting the compressor and draining the oil from it right?Your call. I did a lot of a/c work in KC, Mo. and I had a way I did it but not everyone agreed with my methods but I like to know a/c oil levels and not guess. Your way is assuming the oil level was correct before opening system. My way, IMO, takes the guess work out of it but again, I am spending your money.
So does a recovery machine remove all of the oil from the system or does the compressor have to be removed and drained? @PNW VietVetYour call. I did a lot of a/c work in KC, Mo. and I had a way I did it but not everyone agreed with my methods but I like to know a/c oil levels and not guess. Your way is assuming the oil level was correct before opening system. My way, IMO, takes the guess work out of it but again, I am spending your money.
