What? An EV Tahoe?
GlockandRoll
It's called range anxiety.
It would be RADICALLY cheaper to charge a Tesla at home than $400/month.
A Tesla will roughly cost you about 1/9th as much to drive per mile as an ICE vehicle, yet have 2-3x the power/performance, if not more.
I have several friends with Teslas, model Ss, Ys, even an X, and the tell me it costs them about $3/100 miles driven. And they can smoke a Hellcat from a red-light.
Even the tri-motor 1500hp Cybertruck that I've got on order will go 0-60 in under 2.9 seconds.
That's C8 corvette fast, yet using a fraction of the energy.
WalleyeMikeIII
Sunny and Snowy Minnesota
Are you only counting fuel costs? Because, I think it has been shown that the TCO of a tesla vs a similarly sized ICE sedan yelds the Tesla costing more...
See Video I posted above about TCO.
GlockandRoll
When you consider tax rebates and fuel savings, there's no way my Cybertruck will cost more than my crew-cab ram diesel, assuming they are roughly the same price around $65K.
This is because I drive, on average, 30 miles per day and have for 10 years.
1 road trip over 500 miles per year, at least 1-2 trips to the airport, and a couple of business meetings in Dallas and it puts me right at 10K years. it's always been that way for me, at least for the last decade.
The Cybertruck will put 15 miles of range in my pack each day in just 4 hours of sunlight. We get a LOT more than 4 hours of sun in Texas, so 1/2 of my miles are free based on the assumption that I will drive 30 miles per day on avg.
Sunlight aside, it will cost me about $4/100 miles to drive vs nearly 6x that much.
With sunlight, we are talking $2/100 miles to drive, give or take a few cents.
Now, get rid of $200 oil changes, DEF, and $1K brake jobs as regen braking makes tesla brakes last exponentially longer, and there is absolutely NO way in hell the TCO of my Cybertruck will be higher than my current diesel truck.
If I keep the CT 10 years, which my wife and I have done, my ram will be 8 when I give it to my son when Tesla builds my truck, and my wife's sequoia lasted 10 years before we got her Yukon, it will practically pay for itself with tax incentives, but mostly fuel savings alone.
16mpg at $5/gal for 10K miles = $3,125/year in fuel alone.
Over 10 years, that is a $30K savings, that's half the price of the truck.
Your argument is incorrect, sorry.
todayusay
one factor I seldom see mentioned about EVs is that they'll go through a set of tires quite a bit faster than your regular ole ICE vehicle...sure I can save $40 every 7500 miles by not having to change the oil in my accord, but I'll have to rotate the tires and who knows how much that costs by itself these days $20? $30?....when was the last time you had your tires rotated and no other service performed?
there's all sorts of articles out there debating both sides of it - this one is definitely on the side of EVs but the down side of tire wear coupled with the "need" to buy higher quality tires due to the weight of the EV is pretty hard to ignore as "factor"
Tires are one thing I despise about car ownership as we go through our vehicles fairly quickly since we average over 40k miles/yr on two separate vehicles
DuraYuk
You make some valid points. If you tow a lot ev isn't really the way. Especially over any larger distance. The range drops drastically when towing. Up to 60 to 70% in most cases. Now if all you do is short 50 mile trips then it works out.
I have owned Teslas and my wife currently has a mach e gt and even highway speeds cuts nominal range by 40% and in some cases more.
So plan accordingly.
WalleyeMikeIII
And…you haven’t discussed battery maintenance. I don’t think we know yet on that…too early to tell.
But, at a minimum, discuss it. If it’s a 10 year battery life, you have to count 1/10 of the battery replacement cost per year of ownership. Or it hits you in vehicle value at the end. I rarely see this discussed, but if the battery has depleted to the point where range suffers, it will need a replacement, or the vehicle will have no value. This is real on used Hybrids, it has to also apply for real EV’s.
todayusay
the component left out of the above....that is left out of most "ownership" discussions is the residual value of the "truck" after whatever time period is specified...would also expect the lifespan of the typical EV battery along with the possible replacement cost to be included as well? or is that just ignored in these types of discussions?
i see this all the time on the gas vs diesel discussions...diesel option cost $10k more than the gas counterpart and it'll take 150k miles (or whatever) for the savings to offset the initial cost...yet that only means you did exactly that...offset the initial cost. when the time comes to sell the gas/diesel truck, the diesel retains probably 90% of that initial cost over the gas truck
todayusay
ditto - beat me to it
WalleyeMikeIII
Here is a Car and Driver article on the topic...but even it sort of "discounts" it as a "well, it will happen, but it probably will be cheaper than it is today"
GlockandRoll
A model 3 weighs 3600 lbs, the CT will weigh 7k.
buy, I don't put shit tires on anything as it's the most important part of the car from a performance and safety perspective.
Smityinms
