mharders
Just outside of Seattle
Removed the rubber coating that was peeling from console face. It's getting dark so I'll have to get the rest another day
Sent from the USA.
Did the same thing using a pressure washer, flew right off. I dipped it using anthracite plasti dip and it's a pretty close match to the color and texture from the factory and much cheaper than replacing them.
Sent from my SAMSUNG-SM-N900A using Tapatalk
dubyagee01
I used brake cleaner to remove that gross rubber crap and painted it with dark grey interior spray paint.
SlowD
Hope your enjoying your beautiful weather! Instead of protecting an HD hood I should wrap my whole truck like that to protect it from salt and mag chloride. :)
Fosscore
Yeah man. No complaints with our weather down here. Thank goodness I don't have to deal with that nasty road grime that you guys do.
The paper is off. Here's the HD hood pics.
Pachanga02
Ny
@05alive what did you use (brand)to spray it and where can I get it? I'd like to do it to mine and at the same time repaint the dash, tiny little spots are missing paint.
DPGDirk
Just finished up a bunch of stuff:
Electric Fan swap
Big 3 Battery Cables Upgrade
145 Amp Alternator
New Radiator
New Water pump
New thermostat
New Upper & lower radiator hoses
New Serpentine and AC belts
New Serp and AC belt tensioners/pulleys
New Idler pulley
New air filter
Cleaned MAF sensor and throttle body
(Figured I might as well freshen up all that stuff while I had the front of the engine open)
seven9st surfer
Milton, FL
Finished my 2nd sub install (already have Bose). Factory rear box, Pioneer 8" shallow mount speaker, Kenwood mini amp, JL panel-mounted, color matched grille. Overall, I'm pretty happy with it, but I still have a bit of tuning to do. I think it matches the door speaker grilles a lot better than the factory molded one.
Yukon Lover
Maine
Very nice, ya hated that factory thing. Seat doesn't interfere with the grill? Looks like it still out a bit in the pic.
Sent from my Z797C using Tapatalk
seven9st surfer
Milton, FL
Not too bad. I had cut the hole for a different grille before I found the JL. Hole is slightly bigger than ideal for the new one. Seat touches it a little, but doesn't hurt it.
Oh, and an in progress picture.
shadowid60
