Okay so that tells me whatever happened is inside the seat harness. Check for power to and from the switch.
Sent from my SM-N920V using Tapatalk
And don't forget the other half of the equation- ground. Power does no good without ground!
Where would the seat ground?
Most likely in the harness along with power. I doubt they would rely on the bolts holding the seat to the vehicle and then ground to the seat frame but it's possible.
Got the rear hatch handle changed. I will try to get the others installed tonight.
Did you black out the "TAHOE" on the rear hatch? I'm thinking of doing that on my doors with plastidip .Can't remove it because it was painted before and they taped around it.
Da90
Tulsa, OK
Yeah I used satin black spray paint.
Da90
Tulsa, OK
Thanks man! You have the Denali correct? Man that thing is so clean!
osiris94ej
Casper Wyoming
Yea that too. I assumed by checking for power one would check the ground in the connector. But forget not everyone thinks the same as me.
swazzie
