95escahoe
I think I have the perfect frame for your rear plate, I'll check when I get home. It's black carbon fiber just barely wider than that white border. I have one on mine. If I have it still you can have it if you want it.
Let me know if you still have it or send me a link to it
blown240
over the last couple days I have got a bunch done on my 04 Yukon.
First, I exercised my ISS and my front end knock is gone. AWESOME!
Then I did the Aux Input into the XM radio harness. It worked Great!
Then I swapped my Cig lighter for the Aux charger, and added a couple USB chargers where the AUX used to be. I added a switch so that I can decide when the charger is on, and when its not...
This is the first newish car Ive had in a while. Its 56 years newer than the C10 panel it replaced, and man is it east to work on!
Cattivo
The Concrete Jungle
Finally got my dead TPMS replaced. I'd bought a new one back in April, but just now got over to a shop to swap them out. Then headed to the tint shop to have them redo my windshield because it had a few wrinkles right at eye level on the driver side - small, but drove me nuts. Then when I got back home I programmed all my TPM sensors. While I was airing up the tires afterwards, I decided to try my hand at cutting off the bolt that keeps the seat from reclining all the way. I still need to grease up the end threads, but I'm really impressed by the difference! I didn't bother with the driver side just yet because it's a pain to try to do using my drill with a dremel cut-off wheel (my dremel broke and I haven't replaced it yet). Shortly after I came in to cool off a bit, the mail ran and my Airaid MIT was here, so I got out there and put that on real quick.
Old TPMS:
New TPMS:
Full recline mod on passenger seat, with driver seat fully reclined (unmoddified) for comparison:
Airaid MIT:
Do you have power or manual seats? I want to do that mod to my front seats but not sure if it's possible on power seats
HiHoeSilver
Away!
Chicago
TY Brother
Took me 1/2 hour maybe. Make sure you grease up the new portion of thread. I noticed that the motors weren't real thrilled at first. Had to do a few back and forth. Those motors will trip out under heavy load, so if they stop on you, give it a sec. Go forward just a touch, then back again and it will go farther. You can run that thing all the way until the rod hits the frame of the seat in the front. It also looked to me like if you notched the seat frame in front just a bit, you could go even farther. There is still thread left....
Cattivo
The Concrete Jungle
I should of done that while I had the seats out this past weekend lol...thanks for the tip brother
quikdime
