BlizzardX23
Sacramento, California
Thanks Max...wasnt sure which one it was...but yea, I guess it is the OD...cuz its smaller
You think that does anything for power? or is it just a new shiny piece under my hood?
Max
Mile High
Denver
Spins the alt faster thus increasing output, helps quite a bit since you have the bigger stock alternator. I didn't notice a drop in power when my efans kicked on but I did 1/0 wiring throughout the truck, yellowtop, and keep my gains nice and low.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I checked the date code on my tires: Feb 09.
Checked tire pressures all the way around, they were still the same as when I bought the wheels. I was running them at near max sidewall pressure, 44.5 rear and 42.5 front.
Now that I am sure they are 100% ok, I decided to drop them to near 'door card' pressure. (35 psi)
Dropped the pressures down to 37.5 front and 40 rear, and it rides so much smoother. I no longer feel every imperfection in the pavement.
Once the tires are fully Cold I will double check the pressures and see if there is room to go a little lower.
Max
Mile High
Denver
I swapped nitrogen into my tires when I did the 265/50 and it maintains a much closer static pressure, used to vary quite a bit.
Oklahoma
Just drove the kon today but did get an air regulator for my compresser, and tested it out on my xbox. Its now Orange and Black. Just testing so hopefully I can paint my dash.
Just finished. Aside from the paint leaking through the tape. Looks good. Just need a bigger tank and im gonna paint my dash.
thehoe92
fo sho
The916
drove it to school? lol
I'm loving the fact I actually have shocks now
chris how did you install your OD pulley?
I had Rob at DC Power send me a smaller pulley because I wanted better at idle performance from my alt but I don't have an impact to get the nut off..
Max
Mile High
Denver
Alternator is reverse thread, I just used a big ass breaker bar and held the pulley with the belt loose. I'd like to get a bigger alternator at some point but the truck is fine for the moment, not even sure if I'll hook up the big ass kinetik 2400 I have as it doesn't fit under the hood and I'm uncertain if I want to lose the space under the rear seat. Sigh.
thehoe92
fo sho
The916
it fits ;)
thats so weird, so right is loose and left is tighten
I should be getting close to 230 amps at idle when I swap pulleys
dellguy3700
