mdnitedrftr
CT
Here's a little preview.
4 coats.
Don't mind the garage floor...didn't anticipate THAT MUCH drippage.
I think I'm going to pick up one can of the spray on version just to hit some of the spots underneath that the brushes couldn't really get to, and also for touch ups.
On another note, can anyone recommend a good garage floor cleaner?
brian.roberts.1293
Durham NC
For the guys that have the projector headlights. I was looking at the depo set someone tagged in here. I have a question I have 6k lights in the front end. What kind of light (ie 5k 6k 8k) comes stock in these projector headlights? Can I change over to a nice LED bulb in them?
Sent from my SM-G965U using Tapatalk
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
OEM halogen bulbs are about 4300-5000k light. 6000k is the typical color temp range for LEDs which, is more of just a pure white. No yellow or blue tones to it. If you still prefer though, I'm sure you can find a "warmer" color temperature LED bulb in 4300 or 5000k.
PG01
Up here to the right
4 coats.
Muriatic acid
05Single
afraid of the dark
Finally got time to finish rebuilding my ABS module. I re-soldered all the solder joints and put new heat transfer paste, then scrape all the old silicone glue off and then glued it back together with red RTV silicone. The tricky part is cutting this sucker open! View attachment 204221 View attachment 204222 View attachment 204223 View attachment 204224 View attachment 204225
You're a mad man, and because of that you saved tons of money . Nice work ! Maybe a seperate write up, if I recall this is a common issue with these years right ?
05Single
afraid of the dark
They'll come with cheapy Chinese halogen bulbs. Might still be same bulb 9006 , @Fosscore will know. And 6000k will have a tiny hint of blue. 5000k will be purest white. Try not to use led bulbs in projectors, always hids. I know from personal experience
Levi0320
