95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,157
- Reaction score
- 4,462
Get any footwell lights?
I thought about it but don’t really need them the interior LED’s are so darn bright
PowerTrainProducts
Not familiar with the case saver bit
I hate those clamps. I’m thinking I want to look for spring clamps like factory to use on my trans cooler, or go with AN fittings. I bought the special spring clamp pliers awhile back which make removing/ installing them easy.So....installed a new steering cooler and as another member said, watch those cheap clamps that come with it. It was leaking at the cooler to rubber line connection. I found out that when I checked it with a screwdriver it was bound up on the screw drive of the clamp just before it was really tight. Very small leak. Had to use a ratchet and got it to tighten up. No more issues but I did have to take the grill and headlight out again to find and fix it.
View attachment 210436 View attachment 210437
Front differential, not transfer caseCase saver is a thing that keeps the pump from rubbing its way through the case as has been commonly noted as a known issue.
Make sure you get your alignment checked too. It takes surprisingly little to tweak the stuff outI was rear ended today, 40mph by a dodge ram. Happy I kept my bumper and tow hitch instead of run a rollpan, for this exact reason.
Small dent on lower rear quarter from the bumper. May take it for estimates and pocket the cash. Fix the bumper brackets and call it a day
That's definitely on my list, felt the truck pulling to one side afterwardsMake sure you get your alignment checked too. It takes surprisingly little to tweak the stuff out![]()
Where’d you get the clear housings? Decent quality?I got a set of smoked headlights last year with a set of HIDs i guess they would get way too hot that started to fry the lenses so i got a new set of housings hopefully i dont have that problem with LED
View attachment 210492 View attachment 210493 View attachment 210495 View attachment 210496
